TRD Performance Air Intake
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fgreenva, Nov 3, 2020.
  1. Nov 3, 2020 at 5:49 AM
    Fgreenva
    Fgreenva [OP] New Member
    2021 Tundra SR
    I have a 2021 Tundra SR. The dealer could not confirm the TRD Performance Air Intake System would work on a 2020 or 2021 Tundra, just the 2019 and earlier. Anyone install one on a 2021 and, if so, how did it go? Thanks, Frank
    Part Number: PTR0300140
    Supersession(s): PTR03-00140
  2. Nov 3, 2020 at 6:44 AM
    Welcome from NY.
    Maybe @Roman can answer that question.
    That looks different than mine.
    Fgreenva[OP] likes this.
  3. Nov 4, 2020 at 5:26 PM
    Tundrafan23
    Tundrafan23 New Member
    Works on my 2020 just fine, I assume it will work on a 2021.
    Fgreenva[QUOTED][OP] likes this.
  4. Nov 4, 2020 at 5:37 PM
    Kanobi13
    Kanobi13 New Member
    You already have cold air intake just do drop in filter and air accelerator.
    10TundraSR5 likes this.
  5. Nov 4, 2020 at 5:41 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    It’s an old picture. They used to come with a vacuum gauge.
  6. Nov 4, 2020 at 5:50 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Yea that picture is the 2nd gen trd intake cone style filter. 3rd gen is a flat filter which is good two. It should fit 99% sure. You can also do the sabm mod with the trd intake. I did it on mine and it really made a difference but I have stack mods..
  7. Nov 4, 2020 at 5:56 PM
    :hattip:
    Tundyfundy[QUOTED] likes this.
  8. Nov 4, 2020 at 6:47 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Looking for suggestions on Filter And what is a air accelerator?
  9. Nov 4, 2020 at 7:27 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Looks good but that is about it. I am the only one that looks under my hood so I do not waste my money on cosmetic stuff under the hood.
  10. Nov 4, 2020 at 8:51 PM
    Tundyfundy
    Bay Area, CA
    Air accelerator is the tube that goes from the intake box through the sheet metal into the wheel well. A lot of guys use the aFE dry filter or the TRD filter. https://www.ebay.com/ulk/itm/383733107716
  11. Nov 4, 2020 at 8:56 PM
    Kanobi13
    Kanobi13 New Member
    @Tundyfundy answered it for you. Look into the components of stock vs trd only difference is the cover,accelerator, filter and tube. I did drop in and accelerator and butt dyno did not notice any gains.
  12. Nov 5, 2020 at 4:17 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    TWJLee likes this.
