TRD or AFE Air filter ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stocky Balboa, Oct 3, 2019.
  1. Oct 3, 2019 at 7:08 AM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Looking to replace stock with serviceable filter.
    What’s your thoughts on TRD vs AFE dry S ?
    Pro ? Cons ?
    619Tundra, Rica25 and FlipMonkey21 like this.
  2. Oct 3, 2019 at 7:20 AM
    15whtrd
    15whtrd Mr. Blonde
    I’d say the TRD is no different than a K&N oiled or aFe oiled. The dry aFe is just a little less hassle. I don’t know much about the differences in filtration. If you go to the aFe website it does give you some filtration percentages. I personally have the dry in all three of my vehicles. I also kept my OEM filter so that I can throw it in if I’m going to be in a really dusty environment. I’d say it filters the best.
    The pros of the dry filter in my eyes are not having to buy oil. Just the washing solution. Also zero risk of not enough or too much oil. I’m sure I have been guilty in the past on my vehicles of putting to much.
  3. Oct 3, 2019 at 7:24 AM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    Can't say much since I'm still new to the scene of modding a Tundra but I'm thinking of doing the same for my last mod of the year. I'm thinking TRD and have Toyota service center install it so it does not void my warranty. :) I heard from people that putting an air intake on your truck doesn't really give you any HP gains or mile gains but you can hear your engine louder. :)
  4. Oct 3, 2019 at 7:37 AM
    15whtrd
    15whtrd Mr. Blonde
    I think he’s just talking about a drop in filter and not the entire intake. If you were going to get the TRD intake, install it yourself. It won’t void warranty just because you put it on yourself. Save you a couple dollars.
  5. Oct 3, 2019 at 7:51 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    it will not void my warranty that is good to hear. So back to the topic with the air filter if changing just the air filter will it do the same as changing the whole intake?
  6. Oct 3, 2019 at 8:05 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s debatable. The consensus around here is that any aftermarket intake isn’t going to do much. Maybe a few horsepower, but from what I’ve heard, more noise. Our trucks already have a cold air intake. The TRD box top is a little bigger and it has a smooth intake tube to the throttlebody. Gains are minimal. But they are eye candy, that’s for sure! Personally I just did the drop in aFe dry pro S filter and then added the TRD airflow accelerator to the box. I really don’t know how much it did if anything. But all it cost me was the filter and a $13 part LOL. You can also add the SAMB. (stock air box mod). Either way I feel gains are very minimal, but your personal butt Dyno may feel different LOL. Personally I’ve had my eye on the aFe super stock intake. It keeps your stock box but just gives you the smooth intake tube to the throttlebody. And a silly throttlebody spacer. https://afepower.com/afe-power-55-12551-magnum-force-super-stock-pro-dry-s-cold-air-intake-system
    I also don’t really believe 18 hp gain and 30 Lbs torque.
  7. Oct 3, 2019 at 8:08 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  8. Oct 3, 2019 at 8:15 AM
    15whtrd
    15whtrd Mr. Blonde
    I was going to mention that too. I feel the best options are modified stock, TRD intake, Afe super stock and the S&B. The S&B probably being the best for filtration. But then that comes with the question, good filtration typically means more restriction. So you have to wonder how much are you really gaining other than just more I candy from the S&B? I’m going to assume stock paper filters, filter the best and the S&B may possibly filter even better.
  9. Oct 3, 2019 at 8:16 AM
    e30cabrio
    I have wet & dry filters for my S&B. Dry "feels" slightly better. Both sound great but I have long tubes & full dual exhaust also.
    15whtrd likes this.
  10. Oct 3, 2019 at 8:19 AM
    15whtrd
    15whtrd Mr. Blonde
    The long tubes definitely round off the package there! The intake by itself, meh, but joined with the long tubes, I would’ve done the same.
    SilvenZer02 and Rex Kramer like this.
  11. Oct 5, 2019 at 9:02 PM
    Stocky Balboa
    OC , CA
    Went with the TRD drop in. Thanks for the feedback.
    SilvenZer02 and YardBird like this.
  12. Dec 22, 2019 at 8:05 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I used to use a oil air filter on my other car. A guy came over and wanted to look at my car and mentioned... "I get rid of the oil air filter and go with a good paper filter." Now thinking .. everyone has an opinion I asked,
    "what are you basing that statement on?" Turns out the guy was an engineer from Caterpillar trucks. They tested different air filters. How they did it is the cool part. They imbedded radioactivity into rings. Ran the trucks and then drained the oil. Obviously, more radioactivity meant more wear. That was good enough for me.
  13. Dec 22, 2019 at 8:21 AM
    DSLKSL
    DSLKSL New Member
    Don
    Had a K&N on CAI on mine took it off too much noise no gain.
    Rica25 likes this.
  14. Dec 22, 2019 at 8:21 AM
    What????
    15whtrd, P-Factor and Rica25 like this.
  15. Dec 22, 2019 at 9:16 AM
    Stocky Balboa
    OC , CA
    Went back to stock paper filter after as mentioned no gain in mpg or “performance”.
    Rica25 and Black Wolf like this.
  16. Dec 22, 2019 at 4:00 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Mostly are for sounds.
    Rica25 likes this.
  17. Dec 22, 2019 at 5:20 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Stick with oem. If I had to choose though I’d go with trd.
    Rica25 likes this.
  18. Dec 22, 2019 at 5:38 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Afe Super Dry. Buy two, one in your truck, and one in your garage clean, ready to be swapped.
    Rica25 likes this.
  19. Dec 23, 2019 at 5:11 AM
    Scott G.
    Scott G. New Member
    Scott
    2017 Magnetic Grey Tundra SR5
    2 inch wheel spacers, stubby antennae, LED tail light bar, pop&lock tailgate lock.
    I went the poor mans way to make mine a cold air intake and kept it under $100. I switched the filter out for a K&N high airflow filter for like $61 (Walmart) and then switched out my air flow accelerator for the TRD one $20 from the dealership's online parts store. I'm certain that it works just like the $400 one, just without all the aesthetics.
  20. Jan 1, 2020 at 5:30 AM
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    Does anyone know if the 2019 tundra TRD CAI will fit in a 2020 Tundra? The dealership here is unsure and I hate to buy and go to install and it doesn’t fit!
  21. Jan 14, 2020 at 6:09 PM
    Kevmo
    Kevmo _________
    20 MGM TRD Limited DC
    Yes, it fits fine in my 2020. Very easy install
    King R 808[QUOTED] likes this.
  22. Jan 14, 2020 at 6:10 PM
    King R 808
    Ryan
    Thanks
  23. Jan 14, 2020 at 6:11 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Save your money. Put it in the suspension
    GatorSteve and PlatinumPro like this.
  24. Jan 14, 2020 at 7:46 PM
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    I am of the belief that CAI’s are mostly just a gimmick. They definitely make a bunch of noise, but I’ve never noticed much of an increase in performance.
    Tiamat and PlatinumPro like this.
  25. Jan 14, 2020 at 7:51 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    they're not a gimmick if you coat the cone in snake oil!
    SoCalRandy[QUOTED] likes this.
  26. Jan 15, 2020 at 5:29 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed a AFE dry S in my stock air box the other day... I don't have enough miles on it to provide feedback yet, but it was a good deal and it should compliment the free flowing BAMuffler cat-back I installed 2 1/2 months ago.
    Bakelite likes this.
  27. Jan 15, 2020 at 6:02 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Can anyone provide a link for the best deal on the AFE dry S filter?
  28. Jan 15, 2020 at 6:35 AM
    Rex Kramer
    Georgia
  29. Jan 15, 2020 at 6:36 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  30. Jan 15, 2020 at 6:55 AM
    Bakelite
    Bakelite New Member
    Sam
