TRD Off Road Shocks on a Platinum
Discussion in '3rd Gen Tundras (2022+)' started by RPKEAN, Apr 7, 2023.
  1. Apr 7, 2023 at 2:44 AM
    RPKEAN
    RPKEAN [OP] New Member
    Ryan
    Has anyone swapped the TRD Off-road shocks onto a platinum with the base (non avs) suspension? Everything I’m reading, ride quality is better and these seem to be readily available for a low cost for takeoffs.
    Kap1 and jgoliath like this.
  2. Apr 7, 2023 at 12:01 PM
    Dhust27
    Dhust27 I’m an idiot
    David
    Mississippi
    2023 MGM Platinum CM 6.5 4x4
    Following..
  3. Apr 7, 2023 at 5:58 PM
    pawner
    pawner New Member
    Chattanooga, TN
    2022 Tundra Limited with Leer 100XR
    I've been thinking about this as well, but I have the factory airbags. Will that change anything?
  4. Apr 7, 2023 at 7:02 PM
    RPKEAN
    Ryan
    I have a “base” platinum if that’s a thing…as in no AVS or Advanced package or even power running boards (only bummer). On the plus, I didn’t pay for any bloat options like a safe or $600 cam.
    anyways, curious if others have investigated.
  5. Apr 7, 2023 at 7:21 PM
    desert_gypsy
    desert_gypsy New Member
    Also interested. Is the O/R suspension different than the TRD lift kit? If so, how?
  6. Apr 7, 2023 at 7:22 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I did this on my 2020 Platinum and really didn’t notice much of anything. I’ve considered doing this on my truck now but I’m not sure if it is actually worth it. Another member posted a while ago who had a 1794 and then traded for a TRD 1794 and he said the truck drove the same
  7. Apr 7, 2023 at 8:05 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I have a 22 Limited with rear air suspension. I just ordered a pair of the 22-23 TRD Pro Fox shocks for the rear of my truck. Ill post how it changed the ride and handling after I get them installed
    Kspegar, pawner and eddiefromcali like this.
  8. Apr 7, 2023 at 8:07 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    1794 here with standard non trd shocks.
    Had my camper shell installed today, which added a bit of weight. Truck drives much smoother now. Before the regular non trd shocks were just terrible
    So put some sandbags into your bed, it'll help to soften the ride :)
  9. Apr 7, 2023 at 9:03 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Apples to oranges IMO, I did the same thing to my 2nd gen and the ride improved very noticeably. Third gen has a much different feel when driving.
  10. Apr 8, 2023 at 5:28 AM
    RPKEAN
    Ryan
    I get the impression a lot of owners are not happy with the standard shocks. I threw the question out there to understand if it’s a direct swap give. The low cost of buying takeoffs.
  11. Apr 8, 2023 at 8:53 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Coming from a Ridgeline that drove like a car. The TRD suspension is stiffer but not too bad. We drove an SR5 as well with standard suspension and it was quite stiff. We have "E" tires on it now and the ride is still pretty good. Ours doesn't have any air add-ons and we are packing a 70 lbs cover and 50 lbs of skid plates which probably helps a bit. Soon to add the sliders for another 50 lbs.
  12. May 22, 2023 at 12:15 PM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    @PERRY1060 Did you ever make this swap? Just curious about the results if you did.
  13. May 22, 2023 at 7:03 PM
    PERRY1060
    Perry
    Indiana
    Sorry to say I have not but really want to. Spring is mulch, strip and paint the deck, plant a bunch of stuff for my bride and dewinterize the boat and get it in the water time. I promise to post when I get a caught up:goingcrazy:
  14. May 22, 2023 at 8:29 PM
    Tom976
    Tom976 New Member
    Tom
    Ok have to ask... How much would you say a set of used fox shocks cost?
  15. May 22, 2023 at 9:12 PM
    PERRY1060
    Perry
    Indiana
    Mine were take offs also. Paid $1200.
    ryanwgregg likes this.
  16. May 22, 2023 at 9:45 PM
    Tom976
    Tom976 New Member
    Tom
    I went onto ebay and saw how expensive they are. WOW! Hope you get some serious enjoyment out of them.
  17. Nov 6, 2023 at 5:50 AM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    Are the TRD pro rear sping different than the Limited TRD springs?
  18. Nov 6, 2023 at 6:12 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    As far as I know they are different. Still haven't put them in but reading on the forum over several threads what I've gathered is the TRD pro's are a little softer and tuned to the TRD pro fox shocks. A lot of people towing with their pros have stated how much they sag when towing. The TRD Pro springs (rubber and coil size) do look a little physically different than the Platinum springs currently on my truck. I'm not sure if the rear TRD offroad springs are any different than any other model with the exception being the TRD Pro.
  19. Nov 6, 2023 at 6:48 AM
    Tom
    Tom New Member
    If you ask me the spring should be the same across the trim since the Trd Pro only gets a front lift. Makes more since for Toyota to tune the ride per trim with the shocks. Notice that all the different model have different shocks.
    Yaboy likes this.
  20. Nov 6, 2023 at 7:26 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I did this on my 2018, from the Platinum suspension to the TRD Sport. Along with both TRD sway bars, I noticed the ride is stiffer. I would imagine that you should be able to bolt up the OR suspension no problems.
  21. Nov 6, 2023 at 7:34 AM
    teab
    Ty
    Denver
    This is third Gens not second, so a bit different
  22. Nov 6, 2023 at 7:41 AM
    teab
    Ty
    Denver
    Oooh just noticed the second gen in your profile. Were you asking about leafsprings on a second gen? or were you asking about the coils springs on a 3ed gen?
