TRD Off Road height
Discussion in '3rd Gen Tundras (2022+)' started by TNtundra22, Jun 23, 2022.
  1. Jun 23, 2022 at 1:46 PM
    TNtundra22
    TNtundra22 [OP] New Member
    I've tried to find this info unsuccessfully, apologies if it has been previously discussed. I did see the thread about the height differences among the different trim levels, but I am curious if the TRD OR equipped trucks sit any higher than the non TRD OR trucks? I am wondering specifically about a limited 4x4 CM without TRD OR vs one with TRD OR. Seems like the few I have seen with TRD OR sit up a tad higher but it might just be me? I remember on the previous gen the TRD OR package had no effect on ride height.
  2. Jun 24, 2022 at 5:59 AM
    TNtundra22
    Anyone got any idea here?
  3. Jun 24, 2022 at 6:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    No, should be the same across the trims with the exception of the sport which is a bit lower and then the Pro which will be a tad higher, about an inch lower/higher than the other trims. The rest should be the same ride height, any height difference could come from the tire size based on how the truck is spec'd.
  4. Jun 24, 2022 at 6:53 AM
    TNtundra22
    Awesome, that's what I was thinking but was having a hard time pinning that down, thank you!
