TRD lift making a lot of noise.
Discussion in 'Suspension' started by mr_fusion, Aug 2, 2024.
  1. Aug 2, 2024 at 5:18 AM
    mr_fusion
    mr_fusion [OP] New Member
    was wondering if anyone is having the same experience. Had the lift kit installed at the dealer at 4500 miles. Everything was running smooth for a few months. Now at almost 10k, im hearing a lot of creaking / a click here and there while turning, hitting slight bumps. I understand that a lift needs to settle for a few thousand miles. but even things so much as turning I didnt expect everything to be making so much noise. anyone have an idea what to check, or should i just send it back to the dealer?
  2. Aug 2, 2024 at 7:01 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    Re Torque springs, UCA etc. Are there zerk fittings on the TRD UCA? Hit em with some grease. Do you have a skid plate? Frame flex and skid plate can make some popping noises. Aluminum washers help
