TRD front sway bar spcers with lift?
Discussion in 'Suspension' started by Tundra234, Nov 10, 2021.
  1. Nov 10, 2021 at 5:31 AM
    Tundra234 [OP] New Member
    I have a creaking sound going over small bumps that is driving me nuts. (video to come later). I have the Toytec Aluma coilovers so I'm sitting roughly at 4 inches in the front. Could the creaking be caused by not having the spacer dropdown brackets under the sway bar? I had a set installed when I had a Readylift 3/2, but Toytec told me to remove them when I installed my coilover lift. I'm looking for any suggestions on where it could be coming from. Thanks.
  2. Nov 10, 2021 at 6:09 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    definitely could be sway bar bushings or end links. You are sitting higher, so additional and different areas of stress on both and they are now sitting in a different orientation (they get "set" from years and miles and wear in at the original ride height) . Have you tried spraying them with some lube to see if they quiet down? If it helps, and I think it will, that would indicate you could use new bushings or links. It could also just need some lube in the bushings. Let us know what you find.
  3. Nov 10, 2021 at 6:23 AM
    I will definitely try that. I am off for the next week and a half so I will be able to get some truck stuff done....to include installing my train horns.
  4. Jan 19, 2022 at 1:00 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    @Tundra234 did you ever figure out your issue?
    Im having the same symptoms you mention going over bumps.
  5. Jan 19, 2022 at 2:09 PM
    Yes I did. It was my rear leaf springs in the driver's side.
    Vr0ck[QUOTED] likes this.
