TRD Front Sway + 3" Front Lift = NEW END LINKS?
Discussion in 'Suspension' started by nmpeter, Apr 1, 2019.
  1. Apr 1, 2019 at 3:46 PM
    nmpeter
    nmpeter [OP] New Member
    South Florida
    18' Tundra Cement Crewmax
    I just had my 3" BOSS lift installed today along with a TRD front sway bar. The installer which is very knowledgable with suspension recommended that I look into new end links for the front.
    I did a little bit of searching here and saw that most people didn't install new end links with a lift less than 4". Can I get some opinions from others that have experience with a familiar setup?
    Also, what options are available? I've found Hellwig so far. Still doing some homework on this topic.
    Thanks for the help in advance.
  2. Apr 1, 2019 at 3:48 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I’m lifted 8” and am still using the stock bar and endlinks
  3. Apr 11, 2019 at 1:59 PM
    nmpeter
    South Florida
    TRD sways as well?
  4. Apr 11, 2019 at 2:30 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    The front is not TRD, just the stock SR5 one. I have a TRD on the rear though - had to have those endlinks extended to accommodate
