TRD exhaust dumped after axle. Cons?
Discussion in 'Performance and Tuning' started by IndyTundra, Aug 7, 2016.
  1. Aug 7, 2016 at 12:43 PM
    IndyTundra
    IndyTundra [OP] Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Thinking about changing my exhaust on my truck. I have the dual TRD exhaust but I have never liked the dual side exit tips. I'm thinking about removing the rear pipe kit and dumping it right after the axle. I'd like to keep the rear flanges after the mufflers since I could always go back to normal if I wanted or decided to sell the system. Anyone know of any cons to dumping the exhaust after the axle? Something like this.
  2. Aug 7, 2016 at 5:04 PM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    I say go for it. When I upgrade my exhaust I am going to do a turn down for the same reason. I don't like dual tips out the back or on opposite sides. I would be fine with dual tips on the same side like stock. Turn downs are gnarlier.
  3. Aug 7, 2016 at 5:41 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Check your local law. In PA, you won't pass the inspection. The law specifies that the exit has to be outside the body line of the vehicle.
    MotoTundra, 831Tun and ColoradoTJ like this.
  4. Aug 7, 2016 at 5:54 PM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    Can you say "carbon monoxide poisoning"
  5. Aug 7, 2016 at 6:02 PM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    maybe if it was a sedan and you had holes in the floor pans, but you will not have any issues with CO in the cab if the exhaust is dumped below the bed.
  6. Aug 7, 2016 at 6:04 PM
    mudsweatngearz
    Grant
    Arizona
    Window tint
    I know but try telling the liberal lawmakers that. They would say the gap between bed and cab would create a vacuum thereby drawing CO in through the rear roll down window...yadda yadda yadda
    TRDFaux[QUOTED] likes this.
  7. Aug 7, 2016 at 6:12 PM
    frogger
    Stephen
    Louisville Ky
    too much to list
    You will be fine. The exhaust is gonna dump at the axle it won't be that bad. I've ran turndowns right under the seats of past cars. Only complaint is heat and droning on the highway
  8. Aug 7, 2016 at 8:11 PM
    I see where you're coming from, trust me - but please do not skate the fine line of political discussion.
  9. Aug 7, 2016 at 8:18 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Not really worried about CO poisoning. There are manufactured exhaust made to dump before the rear axle so after the axle is even farther from the cab. I've read some reports of dumped exhaust causing premature bed rust. Anyone running dumped exhaust ever noticed this?
  10. Aug 7, 2016 at 8:33 PM
    Check you local state smog test regs to be sure. The smog probe has to be able to "function" without assistance from the tester. At least here in CO. Do you want to hold the smog test probe while your truck is RPM'd up during the test???
  11. Aug 7, 2016 at 8:35 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Luckily central Indiana has no testing for vehicles. Only testing is up by Lake Michigan area.
    Black Wolf likes this.
  12. Aug 8, 2016 at 3:07 AM
    chphilo
    Western PA
    I remember living in Northen Indians years ago. Fond memories.
    If you have no inspection (and it seems that Indiana law does not specify where the exhaust is dumped. Someone correct me if I am wrong), go for it. If you don't like it, you could always go back. Post up some before and after videos.
  13. Aug 8, 2016 at 5:09 AM
    Alaska was pretty lax on smog tests too if I remember correctly. I don't think it should be a problem. I say go for it too.
  14. Aug 8, 2016 at 11:15 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Thanks for all the replies everyone. I am going to remove the TRD exhaust and go with a MBRP 5320 dumped syatem. I just don't want to mess with the TRD exhaust. I will probably end up selling the TRD exhaust once the new one is on.
  15. Sep 14, 2016 at 5:26 PM
    Seanson
    Seanson New Member
    2010 Tundra TRD Reg Cab Short Box
    Did you end up getting the mbrp? Do you like it ?
  16. Sep 15, 2016 at 5:55 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Yes, I did get the MBRP exhaust. It droned pretty bad at 65-70 mph so I had a MBRP 1013 resonator added to it after the muffler. It now dumps after the axle. Killed most of the drone but still left a good sound. I like it.
