TRD Exhaust Droop
Discussion in 'Performance and Tuning' started by Midnighttaco08, Jan 27, 2017.
  1. Jan 27, 2017 at 8:45 PM
    Midnighttaco08
    Midnighttaco08 [OP] High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Just installed my TRD Dual exhaust.Awesome sound I'll add! Not too loud and just the right tone. :burnrubber:
    Smokes a lot from the oils burning off the inside from manufacturing, which I assume is normal for about a week...
    The thing that gets me is the dreaded droop in the passages side. I've seen a lot of posts about it but can't seem to find out how to fix it... I'm assuming just bend it...:benchpress:But I don't want to screw anything up or bend it the wrong way.
    What is everyone doing?
    geno0506 likes this.
  2. Jan 27, 2017 at 8:48 PM
    scurdyness
    scurdyness One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    Dealer fixed mine, it was level when it was installed but once 'bedded in', passenger side was down around 2 inches....no clue what they did to sort it, sometimes it's best not to ask?
    Midnighttaco08[OP] likes this.
  3. Jan 27, 2017 at 8:48 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Did they install yours? Or did you install?
  4. Jan 27, 2017 at 8:50 PM
    scurdyness
    William
    Fort Smith, AR
    Dealer; was on the invoice so they took care of it, I guess I paid for it in the long run, but.....warranty, etc?
    Oh and BTW, not nearly as loud now at idle (I have 1500 miles into it), but heavy right foot =oh yeah:bananadance:
  5. Jan 27, 2017 at 8:52 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    That's the reason I went with the TRD was to stay with factory accessories...
    Wonder if they would fix it since its a factory universal fit.
  6. Jan 27, 2017 at 8:54 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Guess I've either been lucky or managed to mount mine just fine as I've haven't seen any droop on mine.
    It's now been 5 months and 5,000 miles without issue.
    geno0506 and Midnighttaco08[OP] like this.
  7. Jan 27, 2017 at 8:55 PM
    scurdyness
    William
    Fort Smith, AR
    Worth a try?
    They only took 35 minutes to get mine level, so worst case is $50 labor, depending on where you live, of course...CA, probably $300...ouch
  8. Jan 27, 2017 at 8:56 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    All good lol... my company is relocating me to AZ in about a month or so, so the California inflation should be a thing of the past...
    Maybe a big crowbar :anonymous:
    TXMiamiFan likes this.
  9. Jan 27, 2017 at 8:57 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Mine has the 2" droop on the passenger side.
  10. Jan 27, 2017 at 8:57 PM
    scurdyness
    William
    Fort Smith, AR
    Droop before....
    BOBONTUESDAY likes this.
  11. Jan 27, 2017 at 8:59 PM
    scurdyness
    William
    Fort Smith, AR
    Interestingly enough, I possibly would never have noticed this phenomenon if it was not for this damned site....OCD now...oh my.....
  12. Jan 27, 2017 at 9:01 PM
    r4z0r51o
    Dave
    When I mounted mine I used a hydraulic jack to hold the angle and tighten the bolts down, then just repeated the process on the other side. I used a level to make sure I was straight ...
    Should be easy enough to fix ... Get under there, looses the bolts and use a jack to hold the angle and retighten them bolts. 20-30 mins is all you'd need.
  13. Jan 27, 2017 at 9:01 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Almost same as mine. Mine isn't quite as much droop, but it is defiantly noticeable.
    The OCD is terrible... I've had it for a long time with my vehicles. Pretty much since high school :rofl:
  14. Jan 27, 2017 at 9:04 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Hmmmm... no hydraulic jack, just used jackstands and a friends help.
    There was not problem until I started to torque everything down... then it started to go out of alignment.
    Made sure I torqued evenly to try and avoid this from happening because I read and saw some pics of it.
  15. Jan 27, 2017 at 9:05 PM
    scurdyness
    William
    Fort Smith, AR
    Believe me, it gets worse the more you look at it....until it's fixed, then it's a looksee everyday...same with the Winjet tail lights...I check them every start, something I never, ever did with the stocks...OCD indeed!!!! pretty sad state of affairs but, hey......gott worry about something, right? :rolleyes:
  16. Jan 27, 2017 at 11:08 PM
    r4z0r51o
    Dave
    Yeah I know the feeling ... every time I turn on my headlights I walk out front to make sure the projectors and panamera shrouds are still lit up.
  17. Jan 27, 2017 at 11:50 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I used a 2x4 with a rag on top cut from the ground to the height I wanted the exhaust. I ended up adding some extra cardboard under my 2x4 to lift the pipe up higher than it should be to compensate for the droop after it was tightened. I'm pretty OCD myself and my pipes are perfectly spaced.
  18. Jan 28, 2017 at 1:00 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I noticed mine has a bit of droop, glad to hear it's not just me. I was behind a 1794 today and noticed theirs was drooping too. Now, I come here and it's at the top of the list.
    Thanks Dave. One more item for the to do list.
  19. Jan 28, 2017 at 4:34 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Mine does it as well, I asked the dealer to see if they could fix it, since it drives me bonkers, when the truck was in for service, but it still looks the same, next service I will address it again.
    Dealer installed the exhaust.
    NewImprovedRon likes this.
  20. Jan 28, 2017 at 6:37 AM
    @LOTSOFTOYS did my install and it came our perfect :)
    NewImprovedRon and TXMiamiFan like this.
  21. Jan 28, 2017 at 7:46 AM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Yep same here... looks like I'll be spending some time today unbolting and retorquing :annoyed:
    831Tun[QUOTED] likes this.
  22. Jan 28, 2017 at 9:08 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Drill the holes one size bigger. One hole at a time. Push up on passenger side while tightening.
    Repeat on driver only push down while tightening.
    Repeat until straight.
  23. Jan 28, 2017 at 9:27 AM
    MotoTundra
    MotoTundra The Ocho
    Don
  24. Jan 28, 2017 at 9:56 AM
    geno0506
    geno0506 New Member
    Michael
    I tried several times and got this and its still off by eye and yes I must have OCD!
    but after reading this post I'll try again!
    before
    after
  25. Jan 28, 2017 at 10:13 AM
    r4z0r51o
    Dave
    Looks way better! You'd probably would need a level to see if it's off.
    geno0506[QUOTED] likes this.
  26. Jan 28, 2017 at 10:18 AM
    geno0506
    geno0506 New Member
    Michael
    Yeah I'll try but I is still a wee bit off and a wee bit to me it still a lot lol
    r4z0r51o[QUOTED] likes this.
  27. Jan 28, 2017 at 10:40 AM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    This is next. Tried the loosening and retorquing with a jack stand holding it up level...no change at all.
    I think I've used up my f word quota for today, so tomorrow is another day :rofl:
  28. Jan 28, 2017 at 10:42 AM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Tried bending it? Or re-drilling the holes and adjusting?
  29. Jan 28, 2017 at 10:56 AM
    r4z0r51o
    Dave
    Sorry that didn't help you out. Maybe I just got lucky it worked out for me ...
  30. Jan 28, 2017 at 11:01 AM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    All good man:thumbsup:
    I'd rather try that first rather than drilling :anonymous:
