TRD dual or aftermarket dual exhaust for SC/TRD CAI
Discussion in 'Performance and Tuning' started by PaulROahu, Oct 4, 2016.
  1. Oct 4, 2016 at 5:39 AM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Anyone has a magnuson superchager and TRD CAI in there 3rd gen Tundra 5.7? If so what exhaust and if duals are you running? Looking for an upgrade in performance but really just for the SOUND & FEEL of a superchaged V8.
    Currently I have already placed and got the work order for a 2017 magnetic grey 5.7 Tundra crewmax Platinum edition 4x4, with factory installed TRD CAI and what ever comes with the Platinum package. Also working with Intense Maui Motorsport to do my custom build. What I have decided so far was:
    *Magnuson supercharger
    *12" bulletproof suspension lift
    *2.5" Icon front coil overs
    *(6) rear Icon resivor shocks with custom fab shock mounts
    *BP billet clamps
    *Fuel Moab 22x12 rims
    *Nitto trail grappler 38x13.50x22
    *AMP electronic steps
    *Ruff Riderz fender flares
    *T-Rex Billet grills
    *Spyder front & rear HID lights
    *Aries removable rear mud flaps
    *Spray on bed liner
    *Thule truck bed rack system
    .....big question is what dual exhaust to run? I was quoted a Flowmaster Force2 dual exhaust rear exit. Looking again something with a little BALLS but not
    irritating. Any help or advice to make my dream truck compete. PS. I had a TRD duals on my last 13' tundra and really liked it no issues at all, but seeing if theres anything better. Mahalos for your expert advice.
    walter93 likes this.
  2. Oct 4, 2016 at 7:37 AM
    Check my build thread. Mine is a TRD S/C
    DalTee and PaulROahu[OP] like this.
  3. Jun 16, 2017 at 8:14 AM
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    What did you end up doing? I had the TRD dual installed for about 2 weeks. It sounds awesome and is noticeably faster at WOT but wanted it a little quieter at highway cruising speeds. Since it is straight through mufflers with no baffles (two 6"x24") it seemed to lose a little low end torque from a full stop. It seemed to have to rev a little higher and be a little louder every time I started from a stop which REALLY annoyed my wife. I'm back to stock but am considering just changing the mufflers with some magnaflow with two mufflers (7"x24" or 6"x30") to lower the decibles at highway cruising speeds. Hopefully, that will not dampen the WOT giddyup that I enjoyed with the TRD dual mufflers.
    Any opinions on my draft plan of attack?
  4. Jun 16, 2017 at 9:14 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Got the TRD dual exhaust and in Month installing Magnuson SuperCharger with BullyDog tuner. Also doing my BP 12" lift and the rest of my mods. I plan do do a muffler dump and use my TRD exhaust tips. Try to see if I can put 38" spare tire. If not plan "B"
    As far as the noise mines is not loud but is noticeable, then again I only have less than 400 miles so far.
  5. Jun 16, 2017 at 9:17 AM
    Check out dirtydeedsindustries.com on ther exhaust
    dirtydeeds likes this.
  6. Jun 16, 2017 at 9:21 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Yes I was thinking of using them. Ill run my TRD 1st and if not happy I can always switch
  7. Jun 16, 2017 at 9:27 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    I ran the TRD Exhaust with my SC. You might want to speak with Keith at Dirty Deeds before you order anything. I know you didn't ask but I will say I have serious doubts the stock drivetrain will handle that lift/tires and SC. I predict bad-fantastic things happening. If it's going to be a trailer queen you'll be ok.
  8. Jun 16, 2017 at 9:30 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    2017 Toyota Tundra sr5
    K&n filter, leather seats, stubby antenna
    What are you going to do with your duals ?
  9. Jun 16, 2017 at 9:31 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    Look up dap tune on fb better than Bully my friend has supercharger
    PaulROahu[QUOTED][OP] likes this.
  10. Jun 16, 2017 at 9:34 AM
    KrazieZ
    KrazieZ New Member
    Zachary
  11. Jun 16, 2017 at 10:00 AM
    walter93
    Walter
    Houston
    I'm undecided if I'm going to sell them or alter them with the larger baffled mufflers locally. It is quite the delimna. Give up and sell them, cutting my losses...or spend more $$$ and see if I can alter them to make both me and the wife happy. Hmmmm
  12. Jun 16, 2017 at 10:23 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    I might get these if you don't sell yours read reviews not as loud
  13. Jun 16, 2017 at 10:27 AM
    walter93
    Walter
    Houston
    I'm wanting to keep the exhaust a true dual exhaust if possible, but that Flowmaster is a possibility.
    KrazieZ likes this.
  14. Jun 16, 2017 at 10:48 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    @walter93, I'm not running a SC but I have the TRD duals. I didn't like the small amount of drone or the helicopter sound from the TRD exhaust. I had a local performance exhaust shop install a cross over pipe and it took care of all of my complaints. With the cross over it's pretty mellow until you get on it.
    I would check into this if you want to keep the TRD dual setup.
  15. Jun 16, 2017 at 12:28 PM
    walter93
    Walter
    Houston
    Yes!! the helicopter sound of the exhaust resonating through the floorboard under the driver's feet! I've added 10mm foam sound deadening under the carpet and it lowered it a little bit, but not enough. Where exactly did they install the cross pipe?
  16. Jun 16, 2017 at 1:00 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    I'll take a look and post some pics later this afternoon.
  17. Jun 16, 2017 at 2:41 PM
    walter93
    Walter
    Houston
    On other forums it is stating that an H pipe added to TRD exhaust stops the helicopter sound and adds back some low end torque. Is this true?
  18. Jun 16, 2017 at 2:52 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    I didn't notice any difference. If there was an increase, it would be to small to "feel"
  19. Jun 16, 2017 at 7:03 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    Cross over is between the mufflers and the exhaust manifolds.
  20. Jun 17, 2017 at 10:50 AM
    walter93
    Walter
    Houston
    Thanks. Is that welded into the TRD muffler assembled or the two separate pipes attached to the exhaust manifold?
  21. Jun 18, 2017 at 1:21 AM
    Stewie
    Stewie New Member
    2016 Crew Max
    This is welded onto the TRD section. It's only about 12 to 16 inches in front of the mufflers.
  22. Jun 19, 2017 at 8:02 AM
    walter93
    Walter
    Houston
    Thanks. Looks like you welded yours instead of using the flanges. I'm wanting to keep the flanges so that I can return to stock if I'm not completely happy with it. Looking to have a local shop fab the TRD section with an x-pipe and a pair of 7"x30" magnaflow baffled mufflers (not sure if they will fit since TRD is 6"x24"). Of course, this is based on my online research before I talk to the muffler expert. I'm thinking it will quiet it a little more than TRD mufflers and have enough restriction to retain some low end torque while having the ability to increase flow at highway speeds. Yes, I want to have my cake and eat it too.
  23. Jun 22, 2017 at 11:20 AM
    walter93
    Walter
    Houston
    Did you notice any overall reduction in sound with the crosspipe installation? I'd like it quieter overall. My wife and daughters have very delicate ears :angrygirl::help: If this doesn't work I can either install 7"x24"or 7"x30" mufflers while a third option is a dual in/dual out SUV muffler (not my preferred choice).
    Went to a local muffler shop yesterday and they said they could install one in the same location for $250-$275. Is that a decent price?
  24. Jun 22, 2017 at 12:25 PM
    Spoony1
    Spoony1 New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    This is what is so great about this Fourm. I have been annoyed by that helicopter noise since I got this truck. I read on Tuesday about the crossover pipe and yesterday went to my local muffler shop showed them the picture of what I found on here. Took them about 1 hour cost 75.00 bucks and I feel like I am driving a different truck.
  25. Jun 22, 2017 at 4:17 PM
    walter93
    Walter
    Houston
    I got a quote today for $75 for the part and $75 for the labor. Where is that shop located that did it all for $75?
    Also, did the overall sound level decrease? Did you notice any improvement on the low end torque (starting from a stand still)?
  26. Jun 22, 2017 at 6:11 PM
    Spoony1
    Spoony1 New Member
    Had it done at Red Run exhaust in Ephrata Pa. I don't think it is quite as loud but not a whole lot of difference. As far as low end torque can't say I notice any difference at all.
  27. Jun 23, 2017 at 8:25 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Low end torque loss isn't noticed starting from a stand still.
    Low end torque loss is noticed when cruising down the highway and your truck shifts between 5th-6th constantly back n forth because you have to step on the gas pedal hard enough to downshift just to keep the truck moving forward.
    All tundras lose low end torque with stock exhaust manifolds and dual exhaust. And all tundras downshift back n forth as a result of this low end torque.
    To alleviate this loss, we run an x pipe in our dual exhaust. It doesn't give it the low end torque of a single exhaust. But pretty close. And it fixes the helicopter sound you get by not having a crossover.
    walter93 and T-Rex266 like this.
  28. Jun 23, 2017 at 9:26 AM
    Bl@ckBea$t
    Bl@ckBea$t New Member
    12 Blk Dbl cab
    Dual 12x6 BaMuffler's, Rear-cat Delete, TRD Sway Bar
    So in your opinion, do you think that running an H pipe and X pipe in tandem together will result in lower losses in the low end? I will be using your trd rep system with the trd tailpipes. I have an H pipe currently and running a dual exhaust with no rear cats. Low end loss is rather big lol.
    dirtydeeds[QUOTED] likes this.
  29. Jun 23, 2017 at 11:09 AM
    Cement Pro
    Stock
    So, is theres a truck that's for sale on e bay that's setup about the same.
  30. Jun 23, 2017 at 11:17 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Sorry I just got my 2017 platinum about a month ago and starting to build my truck. I wish it only cost me under $65k to build not close to $100k
