TRD dual exhaust with X pipe
Discussion in 'Performance and Tuning' started by Medic, Sep 20, 2015.
  1. Sep 20, 2015 at 5:00 PM
    Medic
    Medic [OP] New Member
    Ontario, Canada
    2014 Limited Crew Max
    I have got a line on a TRD dual exhaust for my 2011 CM platinum and I am wondering if it would be wise to install an x-pipe and if so, what's the best location. Thx
  2. Sep 20, 2015 at 5:53 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Good question... One I'm not sure you will get an answer to though. My exhaust was built to replace the cat back trd exhaust and was built with an x pipe. They are supposed to keep low end tq and will also make your exhaust more quiet. I don't think I've ever heard of anyone adding one to the trd catback.
  3. Sep 20, 2015 at 5:56 PM
    @LOTSOFTOYS installed my exhaust. Maybe he can chime in.
  4. Sep 20, 2015 at 7:05 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Why would u modify an already properly R&D'd product?
    Black Wolf and jlee like this.
  5. Sep 20, 2015 at 8:00 PM
    Pretty sure a X pipe is not needed with TRD exhaust. Why??? Because it's already tuned. When you drop that much scratch, it better be good to go.
  6. Sep 20, 2015 at 8:36 PM
    Medic
    Ontario, Canada
    I spoke with Keith at Dirty Deeds awhile ago, and it was agreed that an X pipe would eliminate any low end torque loss. Anyone have the TRD exhaust that wants to weight in?
  7. Sep 20, 2015 at 9:47 PM
    DITTO
  8. Sep 20, 2015 at 9:48 PM
    Two totally different setups. Apples and oranges.
    MotoTundra likes this.
  9. Sep 21, 2015 at 6:05 AM
    TruckyTruck
    Gary
    Not really.. Its almost identical. He makes it to fit in place of the cat back and tie into the TRD pipes. Same diameter pipes.
  10. Sep 21, 2015 at 10:40 AM
    Doesn't the TRD come with Borla's? I know Bam's come with straight, straight w/X pipe, and/or optional mufflers depending on what sound you want.
  11. Sep 21, 2015 at 12:00 PM
    Mike Tread lightly.
    south carolina
    If you are not losing any bottom end torque on take off dont worry about it.
