TRD dual exhaust leveling
Discussion in 'Performance and Tuning' started by trowski, Jun 3, 2020.
  1. Jun 3, 2020 at 10:11 AM
    trowski
    trowski [OP] New Member
    I just bought a new 2020 Platinum Tundra and installed the TRD dual exhaust. It sounds amazing! However, the OCD in me was really bothered by how different the driver-side and passenger-side hung. The driver side was at least an inch higher. I thought it was really noticeable.
    I searched a bit on this forum and found others complaining about the same thing, but I didn't find any solutions other than that the passenger side hanger may have been stretched. Comparing the hangers though they looked the same. It appears the hanger mount that comes with the TRD dual exhaust for the driver-side places the pegs closer to the frame, so using the same hanger was going to result in different heights.
    The Tundra (or maybe many Toyota vehicles?) seems a bit unique in that the hangers use two holes on the top, but I tried a hanger using a single peg. That resulted in the pipes having a lot more slop, which I didn't like. So I tried another set off Amazon that worked perfectly!
    https://www.amazon.com/gp/product/B07QBLB977/
    Now they're nearly perfect! I used the middle hole for the driver-side and the top hole for the passenger-side.
    Thought I'd post this here for the next person that wants to level the exhaust and save them a little time and money.
    atc250r, georgiey22, KENNY and 12 others like this.
  2. Jun 3, 2020 at 10:14 AM
    Elduder
    Elduder New Member
    You can also adjust it by loosing the bolts at the tail end of the mid pipe. When I installed my Bamuffler pipes it was uneven, I ended up leveling it just by loosing the rear bolts and having someone hold the exhaust tip level. Torque down and good to go.
  3. Jun 3, 2020 at 10:21 AM
    trowski
    Interesting, I didn't try doing anything like that. The hanger seemed to dictate the height of the tip, since when I took the hanger off it would slump down about where the 3rd hole is in the hangers I bought. Are you able to rotate that connection? If so, that would definitely change the height of the tip.
  4. Jun 3, 2020 at 10:22 AM
    Elduder
    Elduder New Member
    Yes, a little bit at least. I still need to fine tune it, OCD here too.
  5. Jun 3, 2020 at 10:25 AM
    trowski
    Well… now I know. At this point it looks great, so I'll just leave as-is. No use messing with it again.
    Next will be installing the TRD sway bars. The instructions look simple enough, so that should be no problem!
    Elduder[QUOTED] likes this.
  6. Jun 3, 2020 at 10:32 AM
    Elduder
    Elduder New Member
    Rear bar is simple, I havent done the front.
  7. Jun 3, 2020 at 3:51 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I had read about this being an issue for a number of inmates. So, before tightening the passenger side hardware, I used a bungee cord to pull upward on the exhaust tip, holding it upward, then tightened everything down and it seemed to work. Pipes look even to me.
  8. May 2, 2021 at 11:57 AM
    Fat Boy
    Fat Boy New Member
    Ponte Vedra, Florida
    2021 TRD Sport White
    trowski, like you, I am OCD. I paid too much money for the TRD dual exhaust system for it not to be right. My issue was both that one hung lower AND one hung about 1 1/2 inches out further than the other. Your recommendation for the new hanger was great. Now, they are almost perfect. Thanks for the post
  9. Aug 9, 2021 at 10:47 AM
    Marco
    Marco New Member
    The factory rubber mounting that coms with kit will have both sides even. I just installed my TRD dual yesterday. The mounts should all be the same type.
  10. Aug 18, 2021 at 5:19 PM
    Matt56258
    Matt56258 New Member
    Matthew
    Savannah GA
    2021 Tundra Platinum MGM
    TRD grille, TRD dual exhaust
    did the new hangars fix the issue with one side sticking out further than the other? I have the same issue.
  11. Aug 19, 2021 at 6:37 PM
    sledbiz
    sledbiz New Member
    Arizona. USA
    2021 CM 4WD Trail Edition
    Dual TRD exhaust, Katzkin leather. Sway bars FR, TRD PRO grill, headlights and fogs. Full focal audio system. Boost auto power fold tow mirrors
    Thanks for this. Just had it installed today. Not as loud as I thought (that is a good thing) but looks awesome. I purchased those hangers. Somewhere between the bolts and these hangars, my OCD shall be in check.
  12. Sep 2, 2021 at 5:39 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I might have to get one of these. I have one side that is lower than the other on mine also
  13. Sep 2, 2021 at 7:11 PM
    sledbiz
    sledbiz New Member
    Arizona. USA
    I had them loosen and re tighten. They lined up perfectly
  14. Sep 23, 2021 at 8:08 PM
    PapPap
    PapPap New Member
    Tennessee
    2021 TRD Sport
    I did the same and thought they lined up right, but the passenger side extended out the side more, which I really didn't like. I bolted back the original way and zip tied the hanger to cinch it up a bit. It looks much better and will do until I get a $2 hose clamp to draw it up exactly even.
  15. May 1, 2025 at 8:24 AM
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    I'm about to install a take-off TRD exhaust that I purchased. How many of these will I need, and also will I re-use the stock exhaust rubber insulators, or are there new ones that are specific to the TRD kit that I need to purchase?
