TRD dual exhaust - dealer install or DIY ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spotshooter, Apr 3, 2020.
  1. Apr 3, 2020 at 7:11 AM
    Spotshooter
    Spotshooter [OP] New Member
    Kansas City
    2020 MGM Limited DC TRD
    Ride-rite, cover kings, TRD skid plate, TRD sways, power tow mirrors, ... TBD
    This is the only other option I’m thinking about...
    Dealer wants 1,600 to put it on, I need to go look up what I can buy the parts for it, I think it’s around a grand...
    So DIY or Dealer install ?
  2. Apr 3, 2020 at 7:17 AM
    Stig
    Stig New Member
    Depends how you value your time, wrenching skills, physical ability and trust worthyness of yourself or a stranger to do the install and on top of all that how much does $600 mean to you.
  3. Apr 3, 2020 at 7:18 AM
  4. Apr 3, 2020 at 7:19 AM
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    I wouldn't install it.
    Why?
    -It makes the truck sound like a tractor. Have you driven a Tundra on the lot that has it as an option, I did and it sounds like crap.
    -It is a waste of money
    -It adds no resale value
    If you want loud exhaust, go to a muffler shop to have an aftermarket one of your choice installed for less money.
    FYI; I have loud exhaust on my 19 Mustang GT, turns on and off with a switch; this is what exhaust should sound like.
    Bear
  5. Apr 3, 2020 at 7:19 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    I would DIY...its really not a hard task.
  6. Apr 3, 2020 at 7:23 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I would go with @dirtydeeds instead. Either way, I would do DIY...very simple install
  7. Apr 3, 2020 at 7:35 AM
    Spotshooter
    Kansas City
    I ordered the truck without it, but am thinking of adding it... still not sure if I want the extra noise.
    Right now you can’t test drive due to the CoronaVirus thing... so I can’t check them out - I can only go off youtube video sound... so I am holding off...
    the BAM mufflers - first time I’ve heard of them, but it sounds too loud for what I like... looks like I have more research to do.
  8. Apr 3, 2020 at 7:39 AM
    paradizecityz
    Richmond, TX
    For BAMufflers, they make different sizes and the smaller the size, the louder it gets. Are you saying it sounds too loud in regards to outside or in cab?
    Maybe give Keith a call and he can explain the sound and everything. He builds it to what you like and can recommend a setup
    Bob_Wiley likes this.
  9. Apr 3, 2020 at 7:51 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Ditto that.
  10. Apr 3, 2020 at 7:55 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I'll do it for $800. lol
  11. Apr 3, 2020 at 7:55 AM
    multimile
    multimile New Member
    2020 Crewmax Cement
    I did it by myself and i'm not mechanically inclined. It's really pretty easy.
    CaptainGrumpus likes this.
  12. Apr 3, 2020 at 7:57 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Should be a pretty easy install. If you feel comfortable using WD-40 and a socket wrench, you should be fine to do it yourself. But I echo the other comments about BAmufflers — you should really consider it.
  13. Apr 3, 2020 at 8:15 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Do it yourself. It’s super easy.
  14. Apr 3, 2020 at 8:47 AM
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    DIY.
    Easy 2-3 hour job. Get a extra set of hands to help if you can.
  15. Apr 3, 2020 at 8:48 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
  16. Apr 3, 2020 at 9:06 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Same here. Just did a Corsa dB and I think I was done in 2 hours with removal of the old, fighting with one of the hangers and then installing the new one.
    17TundraDCEd likes this.
  17. Apr 3, 2020 at 9:12 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Get yourself a big piece of smooth cardboard ( Kentucky creeper) and go at it. Try not to get your eyeball full of rust
  18. Apr 3, 2020 at 9:40 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    $1600 seems a bit pricey. I was able to get both parts of the exhaust from my dealer for just over $1000 and they charged me $199 for labor. I probably could have stumbled through putting it on myself but the hour and 10 minutes it took the dealer was worth the $199.
    And trust me, you're going to LOVE the TRD Duals! Best purchase I could have made for my truck.
    ARMYGREEN likes this.
  19. Apr 3, 2020 at 10:28 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If you are dead set on duals get the TRD parts and install it yourself.
    If you want a good sounding exhaust system with very little drone, call Keith @dirtydeeds
    http://dirtydeedsindustries.com/
    He will discuss your wants and needs (loudness, towing, etc.) and recommend what you need.
    Everything is bolt on, just like the TRD system.
    You will have to drill a hole in the pipe if you want to install the resonator.
    Not much to it, I've done it twice.
    If you buy from him, I'd install the muffler, run it a week or so and see if you like it before installing the resonator.
    Some use them, some don't, I do.
    I had an 7" and swapped to a 10" single out with the resonator.
    Good thing about DD, if you don't like the muffler, too quiet or too loud, he will swap them out for you.
    You just have to pay shipping both ways, it was around $180 when he swapped mine.
    But that is cheaper than another exhaust system.
    No reason on God's green earth to go to a random shop, have them cut your pipes, and weld in an aftermarket muffler than will give you the drone from the inner depths of HELL.
    Been, there, done that, thanks Magnaflow...
    Call Keith..
    Phone: 760-877-4234 | M-F 9am-5pm PST
    Email: DirtyDeedsIndustries@gmail.com
    Here is his install video..
    https://www.youtube.com/watch?v=i79q3q3kaHs
  20. Apr 3, 2020 at 11:03 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Dealer priced mine around $1600 and I negotiated down to $1200. Simply told them I am not paying $600 for a 2 hour job. They whined like they always do. I ended up not getting the TRD. Over priced in my opinion.
  21. Apr 3, 2020 at 11:07 AM
    Firefly
    Firefly New Member
    2019 Quicksand TRD
    It looks like it could be an easy install, depending on how long your original exhaust has been hanging there and how corroded it is.
    DIY saves you some $$.
    As to why have one, here's one owner's story. The dealer put one on the 2019 Tundra I bought 1 year ago. The truck was the color I wanted, it had the cab style I wanted, and also most of the options I wanted except for the stainless exhaust. I told the salesman that it was a deal breaker and I'd be happy to wait for a truck built to my order. He wanted to move the truck he had on the lot and went to see the parts department and the service guys. He came back and told me they would remove the standard, single pipe exhaust on the vehicle and put in the full stainless system for the same price as a factory install and warrant it the same way. If memory serves, it was around $1000.00.
    Why do this? During the winter this is one of the most heavily salted areas in the country. When I got rid of it, my 13 year old 2006 Tundra with 110K miles on it, still had the original stainless exhaust with no repairs or replacements. Around here, exhaust and muffler shops do a big business due to the corrosion. I wouldn't hesitate to go all stainless again and I like the way it sounds. I keep a truck a long time and this is great investment.
  22. Apr 3, 2020 at 11:59 AM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    What a coincidence. I’m at a muffler shop now literally installing a muffler :)
    I had the Trd duals on my 2018. Didn’t like it.
    1fujifilm[QUOTED] likes this.
