TRD Decals be gone! The easy way
Discussion in '2.5 Gen Tundras (2014-2021)' started by sea_weathered, May 5, 2021.
  1. May 5, 2021 at 9:17 PM
    sea_weathered
    sea_weathered [OP] New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Hey guys. I’ve been toying with the idea of removing my TRD decals for a little while, and finally decided to jump in with both feet. After doing some research, and talking with a buddy of mine who does a lot of detail work, here’s the easiest solution out there! I made a poorly edited video of the process. https://youtu.be/zQHwrrdAPts
  2. May 5, 2021 at 9:26 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks for the post. This looked so much easier than what i did.
    sea_weathered[OP] likes this.
  3. May 5, 2021 at 9:29 PM
    I just used a hair dryer to warm it up and it peeled right off.
    I personally would be afraid to mess up my clear coat.
    Good job.:thumbsup:
  4. May 5, 2021 at 9:33 PM
    sea_weathered
    Pacific Ocean
    I tried that at first, and it was terrible! My decals are a few years old on my 2018 at this point, and maybe they’re baked on with a little age.
  5. May 5, 2021 at 9:34 PM
    sea_weathered
    Pacific Ocean
    It was so easy!
    Ely010606[QUOTED] likes this.
  6. May 5, 2021 at 9:37 PM
    Probably, mine was a few months old.
    Your removal came out great.
  7. May 5, 2021 at 9:57 PM
    sea_weathered
    Pacific Ocean
  8. May 6, 2021 at 5:08 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Same here. Very easy.
  9. May 6, 2021 at 6:12 AM
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    I used a hair dryer to remove the SX decals from my new Tundra. It was easier than I expected it to be.
    WILLINH likes this.
  10. May 6, 2021 at 6:51 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Used this to take the pinstripe off my 4runner. Worked like a charm. I'm hoping I can hair dryer method my TRD stickers though.
  11. May 6, 2021 at 7:33 AM
    Taco-Spike
    Two Trucks
    I just peeled mine off.
    Sierradevil and Bo-Hunter like this.
  12. May 6, 2021 at 12:57 PM
    sea_weathered
    Pacific Ocean
    It seems as though the age of the decals is really the biggest factor for being able to “just peel them off” as this wasn’t an option on my truck. I tried that first and it was a mess!
  13. May 6, 2021 at 2:45 PM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    Those erasers are great. I use them on all my vehicles. Just be carful you don't hold it one spot and burn the paint. Sorry if you pointed it out in the vid. I didn't need to watch it since I remove every badge on every car own.
  14. Apr 14, 2023 at 10:26 PM
    markgraybill
    markgraybill New Member
    Mark
    2023 Tundra 1794 TRD
    Just removed one of the TRD decals on my 2023 Tundra using a heat gun and plastic putty knife and it was rough. In spite of being only a month old the glue was very difficult to get off even using a heat gun. The plastic artwork peeled right off and left a thick white layer which took quite some time to remove. I ordered the tool mentioned above, but am not sure I'm going to use it as I'm worried about the clear coat like some of the others mentioned.
  15. Apr 15, 2023 at 5:05 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Aren't you guys worried about the 10hp loss without the stickers?
    WVI likes this.
  16. Apr 15, 2023 at 6:50 AM
    stogey420time
    stogey420time New Member
    Houston
    Thread back from the dead!
    Thanks to this forum I found the eraser wheel and removed my 9 year old TSS sticker. It also removed with the sticky residue which is awesome. The sticker has been on the truck for so long after removing it I can still see the TSS logo like it's lightly etched on there from factory. I removed the sticker due to the color was fading on the letters otherwise I would've kept the sticker on. Ebay/Amazon TSS stickers doesn't look like the same OEM sticker to me so I opted not to replace it with those stickers.
    After 9 years of owning this truck I am going to start giving it a "face lift." This forum have all the info I need on what I want to do with my truck... happy modding everyone!
    sonofdad likes this.
