TRD COLD AIR INTAKE? Yes or No?
Discussion in 'Performance and Tuning' started by Drewski83, Nov 1, 2017.
  1. Nov 1, 2017 at 5:31 PM
    Drewski83
    Drewski83 [OP] New Member
    2018 sr5 Tundra
    2.5 king suspension front/rear, Icon uca billet, 18" fuel trophy on 35" toyo open country rt
    Is it worth it? Would I see any gains? Hp or mpg's?
  2. Nov 1, 2017 at 5:38 PM
    Save money for something else like most on here would say or you already have one...me i bought one anyways S&B I love it!
  3. Nov 1, 2017 at 5:46 PM
    Drewski83
    2018 sr5 Tundra
    I just place an order for my rhino rb 10 side steps and the stubby antenna. Looking to add some more modifications and wanted to start with the engine.
    SouthBoundSteve likes this.
  4. Nov 1, 2017 at 7:58 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  5. Nov 1, 2017 at 8:04 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    2017 Toyota Tundra 5.7L V8 Air Filter
    • Designed to increase horsepower & torque for the 2017 Toyota Tundra with the 5.7L engine.
    • Washable & Reusable
    • This K&N Tundra air filter lasts the lifetime of your vehicle.
    • Million Mile Limited Warranty with use on Street Vehicles
    A K&N air filter for your 2017 Toyota Tundra should be your Toyota's first performance accessory
  6. Nov 1, 2017 at 8:07 PM
    Pudge
    CT
    If you want a "performance" drop in filter look into AFE Pro Dry filters. No oil and are supposed to filter much better than K&N.
    As far as best way to keep your oil clean, stick with the OEM filters.
    You'll see better power gains from a cat back exhaust from @dirtydeeds than any air filter you can buy.
    lbcdan, Wrongside, Flyinryank and 4 others like this.
  7. Nov 1, 2017 at 8:18 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Save your $$$
  8. Nov 1, 2017 at 9:09 PM
    ToyotaTundraMike
    2015 Tundra
    You won’t notice any gains in mpg or hp, but it does look cool!
    I personally would spend that $$ on other mods.
    Spend a few mins looking around the site and you will find plenty of things to spend your $ on that are more useful.
    Toneau cover, BAMuffler, Esp underseat storage, console safe are a few that come to mind.
  9. Nov 1, 2017 at 9:35 PM
    Drewski83
    2018 sr5 Tundra
    Thank you all for the input, now back to the drawing board...
  10. Dec 7, 2017 at 6:40 PM
    gstults
    gstults New Member
    2017 tundra trd pro crewmax
    Installed the trd cai on my 2017 trd pro. It did make a difference. I recommend it if you want to put out the money. An improvement from take off and low speed acceleration. Very clean install. Better than the others that require a lot of rework. I am very pleased and happy I bought the trd kit. I have read so many negative posts for the trd cai. May be that some just have to complain. If you shop a bit on the web, I found it for $363 with free shipping. Now I am going after the trd rear sway bar. My 2nd tundra trd. My 1st was the 2000. My daughter now has it. Toyota's have been good to me.
  11. Dec 7, 2017 at 6:47 PM
    Save your money.
  12. Dec 7, 2017 at 8:16 PM
    PermaFrostTRD
    Northern NY
  13. Jan 3, 2018 at 4:20 AM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    I'e had volant power core. TRD and s and b, as well as KN drop in. The intakes worked in conjunction with the hypertech interceptor. But in all honesty, could simply be a placebo effect. And every once in a while would toss a code. Switched to stock and found I liked it better. Sold each and every one except drop in.
    KnuckleHD and SouthBoundSteve like this.
  14. Jan 3, 2018 at 5:07 AM
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    So the stock paper filter did better mpg? Thanks
  15. Jan 3, 2018 at 5:17 AM
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    Thanks
    Thundacat and (deleted member) like this.
  16. Mar 7, 2023 at 7:18 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    SABM and send it
