Trd Big Brake rebuild
Discussion in '2.5 Gen Tundras (2014-2021)' started by BradWils, Apr 17, 2019.
  1. Apr 17, 2019 at 1:52 PM
    BradWils
    BradWils [OP] New Member
    7” Procomp lift Procomp MX2.75 Coilovers SPC UCA’s Plus 3” Rear Shackle 35x12.50 R20 Duratracs Pro Com 20x9 0 offset rims Bora 1.5” wheel spacers OEM LED Headlight and Fog conversion LED interior lights TRD Pro Grill Borla Touring true dual exhaust AFE Magnum Force Stage 2 SI Pro Intake Bushwacker Fender Flairs Colour match door pulls, mirror caps and hood buldge Weather Techs Remote Start Factory Match Tint Toyota Bakflip Tonneau cover Line-X
    i just picked up a used TRD big brake kit at a killer deal. The guy I bought them off had them taken off in 2017 and have sat in his garage since then. Other than new pads and turning the rotors, should I replace anything else? Not sure if I can re use the braided brake lines or order new ones if I can find the part number. Any advise would be appreciated.
    Tundyfundy likes this.
  2. Apr 17, 2019 at 2:02 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Lines should be fine. Just check them for abrasion, chafing, bulging, or the braiding coming apart.
    For the calipers, just check the slides and and make sure they are not seized or corroded. Replace as necessary. Otherwise, you should be gtg.
    Hvactech24 likes this.
  3. Apr 18, 2019 at 9:57 AM
    BradWils
    Thanks for the advise... They move just fine so I'll be installing them soon.
    15whtrd likes this.
  4. May 9, 2019 at 8:33 AM
    BradWils
    Do to the brake fluid sitting on the Caliper while it was off the car, I decided to have them cleaned up, rebuilt and powdercoated bronze to match the 1794. Just waiting to pick them up.
    the_midwesterner likes this.
  5. May 16, 2019 at 9:01 AM
    BradWils
  6. May 16, 2019 at 9:04 AM
    BradWils
    Got the Big Brake Kit back from Brightside.. illusion bronze metallic looks even better in person when the sun hits it.
  7. May 16, 2019 at 9:25 AM
    G10dra
    G10dra Not a New Member
    Very nice.
    1. I"d also suggest you upgrade your brake lines to Stainless steel lines.
    2. When you're actually doing this upgrade make sure you DON'T get any brake fluid on those calipers. If you do wipe and wash it off immediately. Brake fluid eats paint. Don't ask me how I know. :(
    3. Get good rotors drilled and slotted or slotted. I"ve used stoptech on my G sedan and I am very happy with it.
    4. Get good NEW brake pad's
    5. Since you're doing all this you might as well flush your brake fluid
    6. Follow proper bedding procedure. This is very important.
    7. ENJOY :burnrubber:
  8. May 16, 2019 at 2:51 PM
    nmpeter
    nmpeter New Member
    South Florida
    18' Tundra Cement Crewmax
    Those look great! Are they OEM? I had no idea these existed.
  9. May 16, 2019 at 2:53 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Dang.....purdy
  10. May 16, 2019 at 3:03 PM
    TheBeast The Beach
    can you run 17"s rims with them or 18"s min ?
  11. May 16, 2019 at 3:08 PM
    BradWils
    They are OEM TRD.. made by Stoptech for Toyota. I think you need 20” to run them. Not 100% tho. I have an extra set made up if anyone’s interested.
  12. May 18, 2019 at 7:54 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    20s are min...
    Rica25 likes this.
  13. Jun 11, 2019 at 12:33 AM
    DiverDave
    DiverDave New Member
    2017 Tundra 1794
    I may be interested in the extra set if you still have them. I have a 2017 Mica Bronze 1794 I am looking to upgrade my brakes. Pulling my trailer has eaten up my brakes!
