Travel Trailer Mods
Discussion in 'Outdoors' started by Alloutdrs1, Jan 13, 2019.
  1. Jan 13, 2019 at 10:13 AM
    Alloutdrs1
    Alloutdrs1 [OP] New Member
    Andrew
    Virginia Beach, VA
    5bfff1e94b62e575db60d418.jpg I recently stepped up from my Pop up camper to a Travel trailer. The wife and I are in the process of transferring over our gear and setting it up getting ready for this years camping season. So for those of you with campers, anything neat you have done to improve the camper itself for function or storage? Curious to see what others have come up with. I have a fairly big front pass through storage I'm trying to get ideas on how to organize instead of everything just thrown in there.
    Also any ideas on things you feel are a must to have would be appreciated as well. Most things will align with my previous camper, but now I have systems like water, a/c, Tanks, heat etc. Stuff I didn't have before and there might be things you guys always keep with your or do from past experiences.
    Tor, classic17, JDL17CM4x4 and 10 others like this.
  2. Jan 13, 2019 at 10:38 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I added a slide out tray to hold my stinky slinky. It’s a plastic gutter (cheap house style gutter) from the hardware store. It slides perfectly into the square pvc housing and makes it much easier and cleaner to use. I took some pics for you, but it’s frozen so I didn’t try to slide it out.
    C5C0D344-C27C-4F77-87FE-F7F41E55ADCE.jpg 23923E94-4B84-4E8F-86FF-AE290FCD5CD1.jpg
  3. Jan 13, 2019 at 10:40 AM
    gdiep
    Syracuse, New York
    I also installed mounting brackets in the front storage pass through to hold brooms, pipe for wdh hitch, tools, fishing poles etc.
    Nice looking trailer by the way!
  4. Jan 13, 2019 at 12:15 PM
    Notachickmagnet
    Notachickmagnet New Member
  5. Jan 13, 2019 at 12:32 PM
    Azblue
    The Dirty T ( ^_^)_且
  6. Jan 13, 2019 at 12:41 PM
    Azblue
    Just noticed that your new trailer has a hand crank jack. Before you worry about buying anything else, get one of these, you will thank me everytime you hook up.
    rdiddy5, KNABORES, AZTundra and 7 others like this.
  7. Jan 13, 2019 at 1:10 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice camper! That’s about the right size imo
    I don’t have pics, but I added an 80 watt solar panel and a sun saver so I don’t have to start the genset when camping without service.
    I have an axle flip kit to lift it in the spring.
    In addition to this a second door step and the fold out hand rail.
    Also the under awning multicolor led light strip with remote is one of my go to mods. They are dimmable, which is very nice for late night conversations.
    Not part of the trailer, but a decent set of mud flaps is top priority for me as we’re down gravel steady.
    Wife did some interior space saving things.
    Garbage bags in a plastic baby wipe dispenser.
    Paper towel holder that’s screwed to the wall under the cabinet.
    Oh and we pack a 5 gallon water jug (like the water cooler ones) with a manual pump in it for drinking water.
    I always have a toolbox with awning tape, exterior caulking/gun, replacement fuses, matches and emergency stuff. A ladder, rope and tarps. Couple air horns, bear spray.
  8. Jan 13, 2019 at 1:16 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Added a second battery, It changed our life ! lol
    aperezsh, gladecreekwy, Tor and 12 others like this.
  9. Jan 13, 2019 at 1:25 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I like that little camper! Definitely makes it easier to get around, huh?
  10. Jan 13, 2019 at 1:32 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yea brother super easy ! We just use it for sleeping and eating, the rest of the time were on the move. I once pulled into a 7 Eleven in downtown LA ! Don't try that with anything else ! lol
  11. Jan 13, 2019 at 1:33 PM
    TruckyTruck
    Gary
    Looking forward to seeing what you guys have done with your campers
    Fit a 39 inch TV on the wall and my PlayStation above.
  12. Jan 13, 2019 at 1:36 PM
    TruckyTruck
    Gary
    Nice! Yeah, I really need to add a second battery
  13. Jan 13, 2019 at 1:40 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    A good surge protector if you ever hook up to shore power.
  14. Jan 13, 2019 at 1:42 PM
    TruckyTruck
    Gary
    I'm pretty new to owning a camper. Actually @ColoradoTJ helped walk me through chosing a camper size and a weight distribution hitch. But I can tell you one thing, having 2 propane tanks seems to be pretty important. Running out of heat in the middle of a cold night isn't fun. I was just using one tank at a time until I froze one night. Now I open them both up and make sure I'm drawing from both.
  15. Jan 13, 2019 at 1:43 PM
    TruckyTruck
    Gary
    Any recommendations?
  16. Jan 13, 2019 at 1:45 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    This! I've got a 30amp surge guard. I've heard horror stories about shore power being hooked up incorrectly.
  17. Jan 13, 2019 at 1:46 PM
    nishibot
    Perris, CA.
  18. Jan 13, 2019 at 1:49 PM
    TruckyTruck
    Gary
  19. Jan 13, 2019 at 1:52 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    100 amp shunt resistor. know exactly how much power you’re using at any time, more specifically, know the AMP draw of whatever you have “on”. waaaay mo’ better than a simple voltage meter to understand battery status. mounted right inside door so I always know when a load is on battery and it’s amp draw.
    bayite DC 6.5-100V 0-100A LCD Display Digital Current Voltage Power Energy Meter Multimeter Ammeter Voltmeter with 100A Current Shunt https://www.amazon.com/dp/B013PKYILS/ref=cm_sw_r_cp_api_i_Gc7oCbNH89MZ5
  20. Jan 13, 2019 at 1:57 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Here’s my setup, before I lifted my truck. 4DDB4D46-0D1B-4F0B-90E9-8D06C4B9A2DE.jpg
  21. Jan 13, 2019 at 2:02 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Does a Motorhome count? I don’t want to post in the wrong thread.
    Hammerhead and Notachickmagnet like this.
  22. Jan 13, 2019 at 2:15 PM
    Azblue
    These are nice: https://www.amazon.com/gp/product/B00IZCNOS0/ref=oh_aui_search_asin_title?ie=UTF8&psc=1 You daw from 1 tank at a time and it automatically switches to the other when one is empty.
    Also, if your trailer doesn't already have one get a battery cutoff switch. You can set to draw from either battery, both, or shut off for storage.
  23. Jan 13, 2019 at 2:22 PM
    Mnorris1206
    08 tundra
    Nice we love our coachman apex. Congrats .
    Notachickmagnet likes this.
  24. Jan 13, 2019 at 2:29 PM
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    I have the same trailer. Love it.
    In addition to the surge protector, consider getting a water pressure regulator and some sort of filters between water hookups and the trailer.
    Lots of youtube videos for "newbie" owners; watch them all. There are some consistencies and some odd-ball suggestions.
    Always check tires.
    Always check connections.
    Always check level :)
    Notachickmagnet and TruckyTruck like this.
  25. Jan 13, 2019 at 2:32 PM
    It is an RV right?
  26. Jan 13, 2019 at 2:35 PM
    AlmightyCrash
    Crash
    San Leon, TX
    That’s what I thought, but it doesn’t get pulled...so I wasn’t sure if it was an acceptable trailer.
  27. Jan 13, 2019 at 2:36 PM
    Mnorris1206
    08 tundra
    I cannot for the life of me remember which two terminals on the plug on the camper you can jumper with a fuse and keep all your running lights on on your camper while it's parked someone might be able to elaborate more on this but the cheapest thing you could ever do
  28. Jan 13, 2019 at 2:40 PM
    TruckyTruck
    Gary
    I don't see why not! Anything you've done to make life better in it would help us all out
  29. Jan 13, 2019 at 2:46 PM
    TruckyTruck
    Gary
  30. Jan 13, 2019 at 2:49 PM
    AlmightyCrash
    Crash
    San Leon, TX
    Ok. I don’t have “before” photos, but just picture your traditional 1995 ugly flowered/southwestern print everywhere with carpeted floors and a tiny full size bed. Honey Oak cabinets, brass hardware and fixtures, etc.
    Some changes had been made when I got it, but I needed to make it more “me”.
    7CC9074B-D362-4C1F-AD33-CA588E69DD95.jpg 30B3E35E-AF0B-4D28-9CE4-1D03B2234506.jpg A09CF753-0B24-499A-91BA-DF0BBDBBC6BE.jpg 4715C6F7-87A6-4984-B0F9-83800615F53F.jpg E75D0621-2757-45BE-AA7E-D3397294BA57.jpg 2350D5E5-C204-4556-AE09-B11094AA402C.jpg
