Transmission warmer "puck"
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2mchfun, Jan 24, 2021.
  1. Jan 24, 2021 at 1:49 PM
    2mchfun
    2mchfun [OP] Cool story, but did your new TTV6 tow a shuttle?
    Does anyone know exactly what this puck shaped warmer is like internally? Is it just a small coil for the heat exchange to occur or what? Just wondering if it has potential to eventually leak and destroy the transmission with coolant. I mean if the right conditions existed such as various components becoming stuck closed or clogged and pressure builds who knows what might blow apart. Had a Mercury product once and it blew apart in many components. Thermostat or not, rigid piping, heater valve, thermostat housing, and a few radiators too. Damn thing was a real headache until I bought a lower pressure cap. Still had some problems even after that.
  2. Jan 24, 2021 at 2:31 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    I wouldn’t worry about it, pretty sure the engineers thought of it already.
  3. Jan 24, 2021 at 2:32 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The post below by @TundraTRD11 comes the closest I've seen to showing the internal configuration of the warmer.
    https://www.tundras.com/threads/transmission-cooler-or-not-thread.76250/page-11#post-1961822
    It is not a simple coil inside a can. The cross-section drawing above appears to show a densely-packed internal heat exchanger of stacked plates. I suspected something other than a simple coil when I saw a warmer schematic showing multiple parallel ATF passes inside the can.
    The diagram in the post above is for the A750 transmission warmer (4.7L), but that is probably not important since all Toyota's warmers of this style will be of the same design pattern. Can you have a failure of the stacked plate exchanger inside the can, and have cross-contamination of the ATF with coolant? Absolutely. But, it won't be pressure that causes the failure; a more likely cause of failure will be corrosion or fatique cracking at exchanger connections. Hopefully, the heat exchanger inside the can is made out of stainless steel.
