Transmission troubles
Discussion in '2nd Gen Tundras (2007-2013)' started by rob cooksey, Oct 21, 2019.
  1. Oct 21, 2019 at 9:13 AM
    rob cooksey
    rob cooksey [OP] New Member
    Rob
    2017 Tundra TRD off road & 2007 SR5 w 8’ bed
    N/A
    So I got in the truck this morning and started and got about 50 feet and the check engine light, VSC off light and the traction control light came on. I drive a couple miles and I noticed that its lacking power and the transmission feels weird. I stop at the gas station to fill her up and While I'm doing that I unhook my negative cable to hopefully clear any codes to make it to work and it worked. No lights the entire drive to work which is about 60 miles.
    Any Ideas?
  2. Oct 21, 2019 at 9:23 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Bad battery.
  3. Oct 21, 2019 at 9:24 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Another vote for bad battery.
  4. Oct 21, 2019 at 9:25 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    AIP maybe?
    My transmission wouldn't "kick down", even with heavy use of gas pedal when the AIP failed. It definitely felt weird, almost CVT-like
    OR18TRD likes this.
  5. Oct 21, 2019 at 9:33 AM
    rob cooksey
    Rob
    N/A
    Ill test the battery and get a code. I saw something that said it could be the gas cap.
    OR18TRD likes this.
  6. Oct 21, 2019 at 9:46 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    People these days "don't have time" to turn their vehicles off (or headlights) while fueling-up, sometimes that's all it takes to throw a code. Being as hard hearing as I am, I've tripped the same codes by not getting the gas cap tight enough.
  7. Oct 22, 2019 at 7:43 AM
    rob cooksey
    Rob
    N/A
    Replaced gas cap last night..... No dash lights yet.
