Transmission trouble
Discussion in '2nd Gen Tundras (2007-2013)' started by Mistagoo, Apr 18, 2021.
  1. Apr 18, 2021 at 3:05 PM
    Mistagoo
    Mistagoo [OP] New Member
    Rodney
    2007 Black Tundra 5.7
    I think my transmission is bad in my 2007 tundra 5.7. I can’t find no one to rebuild it.I was wondering if I can put a used 2008 or above in it.The salvage yards are saying I can only put a2007in it.And they way more money and have way more miles than the 2008 or above.They both have the AB60E.Can someone please help.
  2. Apr 18, 2021 at 3:13 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Why do you believe your transmission needs to be replaced?
  3. Apr 18, 2021 at 3:48 PM
    Mistagoo
    Rodney
    Because it’s slipping between gears.Especially between 1st and 2nd.And it makes a bump or jerk when it goes into the gear.I had 2 codes coming up p2714 and 0751.I had a rear output shaft seal leak.I got that fixed and got the transmission serviced but it still doing the same thing.One code was saying shift solenoid and the other was saying pressure control solenoid.I can’t find no one that will work on a tundra transmission
  4. Apr 18, 2021 at 4:51 PM
    audiowize
    Paul B.
    These are codes specific to solenoids. If you don't want to mess around with it too much, you could simply replace the entire valve body. A Toyota dealership should be able to do this for you. A transmission shop should also be able to do this for you. The places you have called that don't want to do the work likely aren't qualified to. A valve body is about $800. The labor to remove and replace it should be about the same plus or minus a few hundred dollars.
    Also who serviced your transmission? What kind of servicing did they do?
  5. Apr 18, 2021 at 5:01 PM
    Mistagoo
    Rodney
    Toyota serviced it.I think all they did was drain and add fluid.They won’t work on them either.They won’t change solenoids.They only will replace with a remanufactured one.
  6. Apr 18, 2021 at 5:06 PM
    audiowize
    Paul B.
    What's your approximate location? Replacing solenoids does not require the removal of the transmission, so you would stand to save a lot of time and money by not replacing the trans.
  7. Apr 19, 2021 at 5:01 PM
    Mistagoo
    Rodney
    I live in Bay St Louis Ms.That’s what I was told but I can’t find no one that works on Tundras
  8. Apr 19, 2021 at 7:50 PM
    audiowize
    Paul B.
    How about C&O in Nola?
  9. Apr 20, 2021 at 6:24 AM
    Mistagoo
    Rodney
    I’ll look them up.Thanks
  10. Apr 20, 2021 at 1:51 PM
    Mistagoo
    Rodney
    Do you know if they are any good?Donyou know anything about them?
  11. Apr 20, 2021 at 2:23 PM
    timsp8
    NY
    Toyota won’t service the transmission. If it’s bad, they only replace. I had some of the same symptoms and a code for solonoid d and they replaced it in my 2010. Like said above, look for a transmission shop. Even an aamco. Check reviews.
  12. Apr 20, 2021 at 3:16 PM
    Mistagoo
    Rodney
  13. Apr 20, 2021 at 3:19 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Good stuff right here... following.
  14. Apr 21, 2021 at 6:11 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Worst nightmare for me. I’m a standard transmission guy. Good luck, there has to be a
    competent transmission shop near you with modern experience. No reason to jump
    to the conclusion of replacement first.
  15. Jul 30, 2021 at 5:29 PM
    2016ToyTun
    2016ToyTun New Member
    Jon
    2016 MagGrey DC TRD Off-road
    I drained and refilled today. Did it twice. So far no codes after 25 miles.
    My next option would be to replace the solenoid D. I also have the p2714 code. Doing this is much cheaper than a whole trans replacement. Hardest part seems to be crawling under if you don’t have a lift; and refilling the fluid as the fill port is hard to pour into without a pump.
  16. Jul 30, 2021 at 5:41 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  17. Jul 30, 2021 at 5:54 PM
    SouthWestGA
    SouthWestGA New Member
    Way to go! Great Idea!!!
    I used a funnel hung under the hood with hose running down by the brake booster into the fill plug
  18. Jul 30, 2021 at 5:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    1 for tranny, 1 for diff
