Transmission takes longer to switch gears than I’m accustomed to
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Nflguy, Apr 19, 2022.
  1. Apr 19, 2022 at 7:44 AM
    Nflguy
    Nflguy [OP] New Member
    I love my new 2021 TRD PRO but….at low speeds (under 30 MPH) the transmission takes longer to switch gears than I’m accustomed to. It makes a bit of a whiney noise like it’s in the wrong gear or something.
  2. Apr 19, 2022 at 8:38 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    The dreaded shift hang!
    I believe it can only resolved with a tune that addresses the shift points
  3. Apr 19, 2022 at 9:59 AM
    Nflguy
    Is “shift hang” normal for the 2021 TRD PRO or any trim level that year?
  4. Apr 19, 2022 at 10:33 AM
    lloydb82
    lloydb82 New Member
    Lloyd
    2021 tundra limited crewmax
    My 2021 limited does that sometimes while going down a steep hill around 30-40 mph while breaking. Don't hear any gearing noise. The RPMs rises for a few seconds and then goes back to normal.
  5. Apr 19, 2022 at 11:44 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Pretty sure this is normal and done from a safety mindset. Then again, I am used to manual trannys so you get it in neutral and it just goes faster and faster.
  6. Apr 27, 2022 at 6:33 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My 2019 does this, it is normal.
