Transmission still leaking
Discussion in '2nd Gen Tundras (2007-2013)' started by Bassfishinfool, Nov 3, 2020.
  1. Nov 3, 2020 at 4:21 PM
    Bassfishinfool
    Bassfishinfool [OP] New Member
    Michael
    2007 silver tundra trd offroad
    I have had a leak from the extension housing seal and the slip yoke on my 2007 Toyota tundra 5.7l 2wd. So I replaced the entire driveline and slip yoke and extension housing seal and it was good for 2 days now its leaking from the seal it's not dripping alot but it is definitely still leaking
    Any suggestions does anyone think I should replace the extension housing bushing I'm at a lose at this point.
  2. Nov 3, 2020 at 9:29 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Damn... there might be a TSB for this.. Not sure of it's still active... I had this issue with my truck back in 07 and 08, took it in twice for that issue.. I do believe it's the seal that meets with the yoke, If it's what I'm thinking. Back end of the tranny meeting at driveline.
    Black Wolf likes this.
  3. Nov 3, 2020 at 10:20 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    There is a bushing in the tailshaft that can wear out. If it wears enough the shaft will wobble enough for fluid to get past the seal.
  4. Nov 4, 2020 at 9:10 AM
    Bassfishinfool
    Michael
    Thanks ,Ok have you changed that before how hard is it to do. I. Going to just do it my self mechanics will charge a arm and a leg.
    So buy a new seal and new bushing should solve the problem, the bushing is the only part I haven't replaced.
  5. Nov 4, 2020 at 2:57 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
    It can be a pain. You'll need to take the tail shaft of the end of the trans and tap out the old bushing with a long punch then tap the new without nicking it. Easiest way to check the bushing is to give the yoke at the tail shaft a good shake. You should feel no movement up,down, left and right.
  6. Nov 6, 2020 at 4:47 PM
    Bassfishinfool
    Michael
    Would anyone know what the torque specs on the extension housing bolts and if the rtv auto transmission gasket maker will work for making the gasket, cant seem to find one to buy
  7. Nov 6, 2020 at 8:11 PM
    blackdemon_tt
    Yes... make sure it's for the transmission, just bought RTV for my SC400 for the engine and I questioned the cost as it was 13 and when I got there they said 20, so I said it's for the engine so I got a $13 dollar one.. the transmission is $20 more or less in my area..
    Edit: lol didn't answer the question, yes you can buy a felpro gasket, or you can RTV it.. your choice... just wait an hour before filling it up.
