Transmission slow to engage.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lug Nut, Nov 9, 2022.
  1. Nov 9, 2022 at 7:18 AM
    Lug Nut
    Lug Nut [OP] New Member
    2021 Limited TRD
    Bone Stock
    The transmission is slow to engage, when the truck sits for more than 1.5 weeks.
    Start cold engine, place in reverse, and wait about 10 seconds before the truck starts to move. Engagement is slow and soft.
    Drive every day and the transmission locks up like normal.
    Is this typical or should I bring it in for service?
    2021 TRD, Limited. About 8-K on the odometer.
  2. Nov 9, 2022 at 7:47 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Not normal, perhaps fluid level should be checked, its acting low.
    MadMaxCanon, rebmo and snivilous like this.
  3. Nov 9, 2022 at 4:52 PM
    Lug Nut
    2021 Limited TRD
    Bone Stock
    That’s my thought too.
    Thanks.
  4. Nov 9, 2022 at 5:00 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    My matrix did this when low
  5. Nov 10, 2022 at 8:17 PM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    Yup. What they said. Transmission fluid is what automatics use to shift gears. Low fluid, low pressure, poor, slow, or no shifting.
  6. Nov 11, 2022 at 12:16 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Mine has experienced the same and the fluid level is perfect. It's also a 2021. My guess is transfluid is draining back to pan or transmission body and torque converter isn't full. I think it characteristic more than issue.
  7. Nov 11, 2022 at 9:31 PM
    Lug Nut
    2021 Limited TRD
    Bone Stock
    Thanks for sharing your experience. Good to know.
    Yes, fluid slowing draining out of the converter was my other thought.
  8. Nov 12, 2022 at 5:27 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Have about 16k on mine. In someones humble opinion, swap now or at change interval (30k)?
  9. Nov 12, 2022 at 5:40 AM
    MadMaxCanon
    For the first fluid change I think it's good to do early since there will be break in shavings. But after I think 30k or 40k is good. I plan on doing 30k.
    OHwendTrd likes this.
  10. Nov 12, 2022 at 5:54 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Thanks! Plan for it at 30k then. Initial plan anyways, but I like to vet my thoughts through others.
    MadMaxCanon[QUOTED] likes this.
