Transmission slipping and surging, how bad is it?
Discussion in 'General Tundra Discussion' started by EmergencyMaximum, Jun 29, 2022.
  1. Jun 29, 2022 at 3:45 PM
    EmergencyMaximum
    EmergencyMaximum [OP] New Member
    I was at the stop and car on the other side was letting me through, so as usual, heaven forbdi I miss that opportunity!! It was wet roads and I smashed accelerator a little bit and she started spinning a little and trac control started taking over.
    What happened next is, as always, quite terrifying. Road was a little bumpy, so I kept getting and losing traction and, as car was approaching, I was slowly making my progress merging. There was a lot of slipping and lurching while rpms wee getting towards 4000rpm and all sorts of lights(trac ctrl) flashing.:burnrubber:
    How bad is it generally for the transmission when this happens? Is it going to break?:spending: I am not sure how it works, never researched it. I have bald(not very, just almost worn) tires, so if I get caught off guard or it's wet, I can easily lose grip. I try to contain my excitement:yay: most of the time.:smack:
    Thanks gang.
  2. Jun 30, 2022 at 4:15 AM
    blanchard7684
    blanchard7684 New Member
    Step 1 is to ensure you aren't confusing loss of traction with transmission slip.
    find dry, level, asphalt road. drive normally from a dead stop. count the gears as you accelerate. 1,2,3 etc...then it should drop to overdrive.
    If the accleration stalls and rpm climbs you are slipping in transmission.
    Black Wolf likes this.
  3. Jun 30, 2022 at 4:24 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    What you did was either:
    - a brodie
    - a burnout
    - a bake off
    These are signs of high testosterone level. Go ahead and keep your man card in your wallet.
    Saltyhero13, 2mchfun, hagrid and 3 others like this.
  4. Jun 30, 2022 at 4:46 AM
    EmergencyMaximum
    @blanchard7684 , no no transmission pulls fine.
    @TundraMcGov. , yes it was sort of a burnout, but not really, since it was extinguished by rainy condition.
    I must rephrase, when you lose traction and transmission starts slipping and surging so you don't spin out your truck and die in a ditch, does it break the transmission significantly? There is also clicking and ticking happening, but to hear it, you have to be on the mud and more gentle spinning. Ticking is very subtle.
    Edited grammat.
  5. Jun 30, 2022 at 5:23 AM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
  6. Jun 30, 2022 at 5:30 AM
    EmergencyMaximum
    Thank you. I will overview the videos more when I get home.
    2mchfun likes this.
  7. Jun 30, 2022 at 5:32 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Ooh tickling. Yes please!
    hagrid and EmergencyMaximum[OP] like this.
  8. Jun 30, 2022 at 5:33 AM
    EmergencyMaximum
    Found tickle and fixed.
  9. Jun 30, 2022 at 5:42 AM
    Ericsopa
    Ericsopa Old man and the sea
    Your traction control is performed by applying brakes. Has nothing to do with the transmission, so you haven't hurt anything. That's what happens on wet or slippery surfaces. Traction control applies brake to the wheel that's spinning because of lost traction. All the grinding noises you hear are the same ones you'd hear in emergency braking when ABS works to prevent wheel lock-up. It sounds so bad because the system is applying and releasing the brakes multiple times per second.
  10. Jun 30, 2022 at 9:51 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Yeah OP test this out in a dry environment.. I suspect its a lot less problematic as you are making it out to be.. and stop driving like a maniac. and and.. maybe look at your wheel thread.. you may need to better threads.
    EmergencyMaximum[OP] likes this.
  11. Jun 30, 2022 at 3:24 PM
    EmergencyMaximum
    I'm usually normal and careful. Just rare cases, wanted to make sure I'm not excessively breaking things. Thread is almost gone, very fuel efficient now.
    baraynavab likes this.
