Transmission shifting
Discussion in 'New Member Introductions' started by Twofeet2win, Nov 24, 2024.
  1. Nov 24, 2024 at 6:45 PM
    Twofeet2win
    Twofeet2win [OP] New Member
    Christopher
    2007 Tundra SR5
    Bigger rims and tires
    Hello everyone thanks for the add, I'm coming to try and get some info on understanding what my transmission is doing in between shifting it's shutters when shifting from 4th to 5th it started when it shifted to 6th but when I put it in standard shifting and shift it like that it doesn't do it just some ideas or if anyone has experience this situation again anything is helpful I am a little mechanically inclined?
  2. Nov 24, 2024 at 7:59 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Nov 24, 2024 at 8:09 PM
    Have you checked the transmission fluid level? Honestly sounds like torque converter shudder. Ever had the transmission serviced?
    Mdl and FrenchToasty like this.
  4. Nov 26, 2024 at 7:21 PM
    Welcome from NY.
  5. Nov 26, 2024 at 8:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    The 2007 and 2008 Tundra had weak spring dampeners in the torque converter. Combined with this weakness and flex lock it would overheat the torque converter. Usually they tried to reprogram and ultimately installed new torque converters. I had a shudder in my original transmission but replaced it with a 2010 when it failed.
    KNABORES likes this.
