Transmission shifting to lower gear
Discussion in '2.5 Gen Tundras (2014-2021)' started by WX4SNO, Jan 4, 2019.
  1. Jan 4, 2019 at 9:07 AM
    WX4SNO
    WX4SNO [OP] New Member
    Anthony
    Snowville, VA
    2019 CM Limited 4x4, 5.7L Cement Grey
    I just picked up my 2019 Tundra on December 5th. I have about 1,200 miles on it now and while driving I have noticed that when I am cruising at about 40 mph or so and I gently hit the brake, the engine revs up and the transmission shifts into a lower gear. It seems to happen more often when I am going downhill, but I have noticed it on level ground as well. It just feels like it's engine-braking when I just barely tap the brakes to reduce my speed...but it really throttles down. My old '98 Tahoe would only shift down if I really applied the brakes and wanted to significantly reduce my speed. Is this normal for the Tundras?
    Y0TA PR0 likes this.
  2. Jan 4, 2019 at 9:41 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Seems like I’ve caught my ‘18 doing this, down shifting and slowing me down rather than letting me cruise down a hill... which then leads to me having to hit the gas to speed back up
  3. Jan 4, 2019 at 9:58 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Following. I've noticed this in my 2019. Curious is the seasoned owners can verify if this is normal or an issue.
  4. Jan 4, 2019 at 10:01 AM
    WX4SNO
    Anthony
    Snowville, VA
    Exactly! I have to do the same thing and it's more than a little annoying, but would like to know if it's normal or if I should have it looked at.
  5. Jan 4, 2019 at 10:02 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    yep, rev matching and everything. Saves your brakes. "normal"
  6. Jan 4, 2019 at 10:05 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Grade logic transmission programing. Normal.
    Ronin and WX4SNO[OP] like this.
  7. Jan 4, 2019 at 10:59 AM
    WX4SNO
    Anthony
    Snowville, VA
    Thanks folks...I figured it was something to do with the computer!
    Rica25 likes this.
  8. Jan 4, 2019 at 1:54 PM
    It’s just the computer trying to learn your driving habits.
    Rica25 likes this.
  9. Jan 4, 2019 at 2:10 PM
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    It does it on my 07 too.
    equin likes this.
  10. Jan 4, 2019 at 2:37 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Normal. My ‘15 has done it since it was brand new.
  11. Jan 4, 2019 at 2:44 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    My 15 does it. That's normal
  12. Jan 4, 2019 at 2:46 PM
    Blueknights75
    Ron
    Clayton, NC
    :burnrubber:My ‘18 does it and I love it. Feels and sounds a little like a trans brake.
  13. Jan 4, 2019 at 2:46 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Never noticed in our '14 I will be paying extra attention to the Tundra this weekend and this is my 420th post so what else is there to do but:rasta::rasta::rasta::rasta:
    OR18TRD and Y0TA PR0 like this.
  14. Jan 4, 2019 at 8:05 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    My '18 does it. I'm actually very happy with the pattern of when the engine braking kicks in. I think it's very effective, doesn't kick in at the wrong time, etc..
    TokerJoker and Y0TA PR0 like this.
  15. Jan 4, 2019 at 8:11 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Yup normal. Mine does it especially when I’m going down hill or when I’m towing my trailer and also going down hill
  16. Jan 4, 2019 at 8:11 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Hell ya! :D:rasta:
    TokerJoker[QUOTED] likes this.
  17. Jan 4, 2019 at 8:15 PM
    AZTundra
    Paul
    Phoenix, AZ
    Agree, this is normal and nothing to worry about.
  18. Jan 4, 2019 at 8:17 PM
    ToyotaTundraMike
    2015 Tundra
    Glad I saw this thread because I have always wondered if normal. I have only noticed it going downhill.
  19. Jan 4, 2019 at 9:25 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Same I like the engine braking feature
    fundra_goes_west and OR18TRD like this.
  20. Jan 5, 2019 at 12:55 PM
    grant1047
    grant1047 New Member
    Grant
    2017 1794 white
    Normal my 17 does it also.
  21. Jan 5, 2019 at 6:34 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    The Tundra does not downshift, however I almost never hit the brakes to cancel cruise, I pull the little toggle to me and the truck just coast just as smooth as can be. I will be trying the brake pedal tomorrow while out and about. Carry on and enjoy the evening and GO COWBOYS!!
  22. Jan 6, 2019 at 7:51 PM
    Tundraguy12
    Tundraguy12 New Member
    David Myers
    2015 Black Tundra TSS CrewMax
    Winjet Tails 5% Tint all around
    Maybe disconnect the battery with the headlights on to denergize all power from the computer. Plug the Battery back up after about 30 min and see if it will correct itself. But that’s normal in most cases.
  23. Feb 13, 2019 at 7:09 PM
    WX4SNO
    Anthony
    Snowville, VA
    Thanks for the replies folks...getting used to this more now, but still find it annoying at times.
    I have noticed though that it seems like the Tundra just can't find the right gear...it's always wanting to shift around searching. I'm hating that more than the downshifting when I tap the brakes!
  24. Feb 13, 2019 at 7:11 PM
    Jengel451
    The Bitterroot, MT
    Welcome to the modern era. You think the tundra is bad? You should drive any newer 8 speed rig.
    Stormtrooper81 likes this.
  25. Apr 25, 2019 at 2:39 PM
    BillysTundra
    BillysTundra New Member
    2014 Black 1794 with towing package
    Added Ranch Hand brush guard (deer protection)
    I bought an 014 9 months ago and noticed the issue right away. As you might expect, the dealer was clueless other than to say it was normal. I don't necessarily object to the down shifting but it does not seem consistent. Sometimes it occurs "automatically" and other times when I lightly tap the brake. I'd just like to be able to depend on it or be able to control it myself - don't appreciate surprises. I bet there are plenty of Toyota engineers watching these forums and getting a good laugh out of our comments. It would be great if one of them would give a simple tutorial on how the system works and how we might more effectively interface with it.
  26. May 13, 2019 at 6:15 PM
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    Mine does the same thing too.If you don't like it or want it to do that then switch to S and up shift it to 6th gear and that down hill brake will not engage. Just a FYI. And you can leave it in S (shift mode) it will shift normally.
    CMB likes this.
  27. May 13, 2019 at 6:19 PM
    PA452
    PA452 New Member
    Pretty sure I've had mine downshift while in S. Pretty rare that I use S, just was on a trip to the Smokeys a couple weeks ago and used it a lot coming down mountains.
  28. May 13, 2019 at 6:33 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    My 13 crewmax does it also The way I have found to stop that is to shift into "manual"shift and shift into 6th gear.it will bypass the down shift.I have tried it many times and it works every time!
  29. May 13, 2019 at 6:45 PM
    PA452
    PA452 New Member
    Yep, same.
    But I must say, in general I've been impressed with the downshifting trend of my Tundra. I usually find it downshifts at the appropriate times when I would want it to. In the mountains, it was a different story as I'd be coasting down windy roads for over half an hour.
    My 2015 Tacoma on the other hand, it never downshifted how I wanted it to. I used to manually downshift it a lot more. It was the first automatic transmission I ever owned, and it would drive me nuts sometimes. When I wanted it to downshift, it wouldn't. Other times I'd want to coast down a hill and gain momentum but it would decide to downshift and hold me back.
  30. May 13, 2019 at 6:51 PM
    tenntundra
    Walter
    Tennessee
    I live in a mountain area also ,and the down shift has saved me a lot of brake wear.Plus the dual exhaust has a nice rumble when it down shifts!!
    Tundyfundy likes this.
