transmission shifting hard
Discussion in '3rd Gen Tundras (2022+)' started by gogators13, Feb 25, 2025.
  1. Feb 25, 2025 at 5:38 AM
    gogators13
    gogators13 [OP] New Member
    rodney
    2022 limited tundra
    I have a 22 limited with 35,000 miles. I have noticed when driving on interstate and I go to give it extra gas to pass, I feel the truck/transmission shift really hard. Its not like I'm driving the truck hard. I'm only talking about going from 75-85 to pass. This is the only time it does this. Anyon else have this problem. Is it something I should have looked at. TY
  2. Feb 25, 2025 at 5:40 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Hard or fast? Is the “hard” shift on the downshift to pass or shifting back up?
  3. Feb 25, 2025 at 5:59 AM
    gogators13
    rodney
    2022 limited tundra
    The downshift
  4. Feb 25, 2025 at 6:51 AM
    Danman34
    Danman34 New Member
    Danny
    That’s called passing gear. If you mash the throttle, the transmission is supposed to downshift fast to keep up with the throttle input. Ide be more concerned if you pressed the gas and it took a long time to shift. That’s bad. Fast downshifts are a good thing. The faster it shifts, the less heat is produced at the clutch packs.
  5. Feb 25, 2025 at 8:43 AM
    gogators13
    rodney
    2022 limited tundra
    Ok I understand what you're saying but it just downshifts harder than any other truck I have ever owned. Its almost like a really hard jerk and popping sound at the same time. It must be nothing because it never does it any other time. TY for your time.
  6. Feb 25, 2025 at 9:37 AM
    Danman34
    Danman34 New Member
    Danny
    Did you just get the truck? Or have you had it since new and something has changed?
  7. Feb 25, 2025 at 9:39 AM
    gogators13
    rodney
    2022 limited tundra
    I have had the truck since 20,000 miles, I can't remember when it started as I don't drive on interstate very often, but it has been doing it for a while.
  8. Feb 25, 2025 at 10:10 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    40K is about the time they recommend a transmission service. It looks pretty straightforward.
  9. Feb 25, 2025 at 10:33 AM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2024 Tundra SR5
    My 22 did the same thing, even after 40k miles and a transmission service. It would clunk hard while downshifting on the thruway. When I brought it up to the dealer they told me it’s normal because it’s jumping a few gears . My 24 does not do this at all.
    Tundrastruck91 likes this.
  10. May 1, 2025 at 2:37 PM
    edwinoromero
    edwinoromero New Member
    Today
    Edwin
    i have Tundra 2024 hybrid, 64k miles.. i started feeling it when i applied reverse, and comeback to Drive... really hard shift... Some Ideas???
