Transmission Service
Discussion in '2.5 Gen Tundras (2014-2021)' started by hvychev77, Sep 2, 2024.
  1. Sep 2, 2024 at 12:19 PM
    hvychev77
    hvychev77 [OP] New Member
    2017 crewmax
    I have a 2017 tundra crewmax with 54k on it. i want to service my transmission. just curious, how many of you drain and fill without changing pan gasket and filter? does it have a filter or a screen?
  2. Sep 2, 2024 at 12:23 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    many will tell you
    don’t mess with the pan, gasket or filter
    just do a drain and fill
  3. Sep 2, 2024 at 12:46 PM
    hvychev77
    2017 crewmax
    that’s what i’ve been seeing online as well.
  4. Sep 2, 2024 at 12:51 PM
    blenton
    blenton New Member
    I am in this camp. I’ve done a half dozen drain and fills on my truck without dropping the pan or filter. The filter is more of a screen instead of the microfiber filter media of most transmission filters so it doesn’t need to be changed frequently like most filters.
    Reason to avoid dropping the pan unnecessarily is that the bolts can seize in the case and snap off. If you live in the rust belt you usually have a higher chance of this happening. If you are careful and lucky, you may avoid broken bolts. But be prepared to drill and tap just in case.
  5. Sep 2, 2024 at 1:18 PM
    hvychev77
    2017 crewmax
    ugh… no thanks!! i can drain/fill myself or have it serviced where the filter/gasket are replaced for $250… i’m on the fence with it…
  6. Sep 2, 2024 at 1:40 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  7. Sep 2, 2024 at 3:08 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    If it’s not leaking, then all you need is just a drain and fill.
    Most will tell you to pay attention to the temps, but ultimately, warm up the truck, warm up the trans, measure drained amount, and then fill with same amount drained.
