Transmission service
Discussion in '2nd Gen Tundras (2007-2013)' started by rnciholson14, Mar 15, 2024.
  1. Mar 15, 2024 at 9:55 AM
    rnciholson14
    rnciholson14 [OP] New Member
    I know this question has been discussed a bunch, but looking for advice for my specific situation. I bought a 2012 limited with 150k on it… transmission feels fine but I have no idea what the service history of it is. I called a AAMCO transmission shop to ask what they thought and they said to just leave it and not worry about it (don’t even drain and fill). What would you guys do with it?
  2. Mar 15, 2024 at 9:58 AM
    JohnWhicker
    JohnWhicker New Member
    Just do it as you don't have any history. Do a full service, drain and everything. Peace of mind. Unless you have full service history I would consider the other major items before 150K, spark plugs, differentials, etc, etc. Part of a purchase should be service history and maintenance.
    snivilous likes this.
  3. Mar 15, 2024 at 11:36 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Would agree with @JohnWhicker Just start somewhere. There are peeps on here who have never changed it till like 250k, like yours truly. I've had some documented services due to issues with the transmission, and dealership has conducted some of these as part of the package. As of now, I'm draining and filling every 30K miles or so, at least the pan, which drains out about 4 quarts, but there is 6 in there.... If you do 4 quarts every oil change, and you drive enough to do it in a year, then you will get about 80-90% of the fluid out there in that year..
  4. Mar 15, 2024 at 1:36 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Important- do drain and fill only. Don't let a shop do a transmission flush.
    blackdemon_tt likes this.
  5. Mar 15, 2024 at 7:05 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    There are definitely 12 ish quarts in mine, and the level is correct.
  6. Mar 15, 2024 at 7:13 PM
    blackdemon_tt
    Not questioning it.. I know because I've pulled my transmission pan.. 4 quarts drained and there were 2 more still in there.
  7. Mar 15, 2024 at 7:17 PM
    Dalandshark
    Northwest
    I see what you’re saying, but it also circulates through the torque converter, will take 3-4 pan drain and fills to really get through all of it.
  8. Mar 16, 2024 at 4:15 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    That's the point...slow and steady.
    ChesterTundra likes this.
  9. Mar 16, 2024 at 5:57 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    I'd probably do 4 drain/fills over the course of the next 3-6 months. Fluid is way cheaper than a new transmission!
