Transmission rear seal leaking 2000 AC 2WD 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Feb 20, 2023.
  1. Feb 20, 2023 at 5:12 PM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    South Carolina
    Crawled under my truck and noticed small ATF leak where driveshaft yoke slides into rear of transmission along with fluid being slung onto underside of body there. Looks like simple job to replace. Any gotchas, pitfalls or other warnings I should be aware of before I start? Thanks.
  2. Feb 21, 2023 at 1:08 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Not sure, but I would start by reading the FSM covering that system. Some good tips in there.
  3. Feb 22, 2023 at 10:41 AM
    Alltimehigh
    Alltimehigh New Member
    I thought this was a seal as well. Turns out the yoke (at least on my 2004) is defective so I had to buy a new yoke and install. Stopped all leaking. Some people were able to fix it by patching the yoke with JB weld/actual welding... I was not able to.
  4. Feb 22, 2023 at 1:14 PM
    bfunke
    South Carolina
    I read somewhere there was a TSB for 2004 defective yolks where they leak around a plug that is pressed into the end. I’ve had some buds fix theirs either with JB weld or melting some plastic in the end to seal it
  5. Apr 30, 2024 at 8:40 PM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    So definitely plug this hole it's not a breather hole correct?
