Transmission problems
Discussion in 'New Member Introductions' started by tmade6999, Jan 23, 2021.
  1. Jan 23, 2021 at 10:21 AM
    tmade6999
    tmade6999 [OP] New Member
    01 sr5 Tundra
    3"lift with 33×12.50×18
    Texas here 01 Tundra sr5 with 3" suspension lift 33×12.50× 18. 175,000 and tranny made a loud pop as i was backing up over a curb. Now it has no forward or reverse. Any recommendations? Ot will a tranny out of Sequoia work? Or does anyone know a website that i can search salveage yards for a tranny?
    TXRailRoadBandit73 and YardBird like this.
  2. Jan 23, 2021 at 10:22 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  3. Jan 23, 2021 at 11:01 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
    https://www.car-part.com/ will give you access to search for used parts from any salvage yard that is part of that network (which is a LOT). From there, you can filter down by "interchange" years/models and by distance, and other details.
  4. Jan 23, 2021 at 11:08 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Good luck with your search!
  5. Jan 23, 2021 at 12:12 PM
    B33
    B33 New Member
    don't know if you can but if you have a bad trans check and see how hard it would be to instal the 5 speed AT in your truck
    I think they were 05 -06 and I know there in the 2007 4.7l
  6. Jan 23, 2021 at 12:31 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Where is the truck now? Is it still setting where you heard the loud pop?
    Before you buy a transmission, you may want to do some basic diagnosis.
    snivilous likes this.
  7. Jan 23, 2021 at 1:00 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'd be surprised if the transmission just randomly blew itself up going over a curb. I'd bet your driveshaft, axle shaft, tcase, etc. had an issue. Have you crawled under it and seen if there's something obvious and tried to drive in 4wd?
  8. Jan 23, 2021 at 1:01 PM
    JohnLakeman
    Exactly what I thought. Transmissions fail, but rarely from applied load.
  9. Jan 23, 2021 at 1:32 PM
    tmade6999
    01 sr5 Tundra
    So i checked out the driveshaft and it seems to be good. I can put the truck in gear and seems like it wants to move but there is a wining sound but when i put it in park it grinds like the truck is moving and you put it park while moving also there is some fluid at the tail piece where it connects to the dtive shaft. Any ideas?
  10. Jan 23, 2021 at 1:38 PM
    JohnLakeman
    With the fluid leakage at the tail shaft, it sounds like your transmission output shaft yoke may have broken at the end of the output shaft. Leakage says there's unusual shaft movement inside the seal that's causing the leak. The noise you're hearing may be from the output shaft end turning against the yoke.
    I would drop the driveshaft and remove the output yoke for inspection.
    2mchfun likes this.
  11. Jan 23, 2021 at 1:40 PM
    tmade6999
    01 sr5 Tundra
    Ok. Thanks for the info. I will get on it now.
  12. Jan 23, 2021 at 2:51 PM
    JohnLakeman
    Mark the u-joint companion flanges so the driveshaft can be reinstalled in the same position to maintain balance. Plan on replacing the tail shaft seal if the transmission is OK.
    2mchfun likes this.
  13. Jan 26, 2021 at 8:06 AM
    2mchfun
    The pump itself may have also cratered. When all gears are gone and you can still roll it with nothing binding or grinding in neutral. I say either output shaft or failed pump.
  14. Jan 26, 2021 at 8:06 AM
    2mchfun
  15. Jan 26, 2021 at 8:10 AM
    2mchfun
    If your going to keep the truck, imo, rebuild tranny, no salvaged who knows what. I always go with if you can't afford it once, how will you afford it twice? Logic.
  16. Jan 26, 2021 at 4:48 PM
    Ronster
    Ronster New Member
    Ron
    2017 Tundra Crewmax
    Will it move in 4wd?
  17. Jan 27, 2021 at 3:24 AM
    Welcome from The RGV
