Transmission problems
Discussion in '2nd Gen Tundras (2007-2013)' started by Mali8080, Jun 23, 2023.
  1. Jun 23, 2023 at 6:49 AM
    Mali8080
    Mali8080 [OP] New Member
    2016 Toyota tundra 5.7 eng 4*4 no check on dash, when start the truck and shift all gears inplace shifts normally after warming up D gear late engagement with big sound like hit from behind, connect scanner and drive for 20 miles scanner showed p0766 current ,p0756 pending, p0776 pending, p2714 pending and p0766, I hav the Trans fluid flashed and still the same
    Any opinion or Idea about this are welcome
  2. Jun 23, 2023 at 6:59 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Codes indicate issues with solenoids. You may need to get a transmission shop to test all 3 solenoids for resistance, i do believe they can do it from the outside. Worst case they will need to drop the pan and replace these solenoids. If you got the transmission flushed this may be the cause for additional problems. Most people recommend the drain and fill method over time for transmission service.
    Mali8080[OP] likes this.
  3. Jun 23, 2023 at 7:03 AM
    Mali8080
    I flashed after the proplem
  4. Jun 23, 2023 at 7:30 AM
    blackdemon_tt
    Yeah I understood that, but the solenoid electrical connectors may be damaged, coming loose or the solenoid have failed all together. I may lean towards they've failed since you have a code and a pending code, it's usually a clue.
    MTRock and Mali8080[OP] like this.
  5. Jul 3, 2023 at 4:34 PM
    Mali8080
    SL1 solenoid replaced and problem solved, truck running smooth , everything seems to be ok. Thanks everyone.
    MTRock, Y0TA PR0 and VWTim like this.
