Transmission problem
Discussion in '2nd Gen Tundras (2007-2013)' started by kadashe, Aug 31, 2017.
  1. Aug 31, 2017 at 2:24 PM
    kadashe
    kadashe [OP] New Member
    2008 Tundra
    I have a 2008 Tundra that I am having issues with the transmission. They keep telling me the transmission is building up too much pressure and it is causing tranny fluid to ooze out around the pump seal and shaft seal . Had the transmission rebuilt in April by a local reputable transmission shop because the local Toyota dealer was giving me the run around I felt and did not want to address the issue until it was out of the extended warranty. Anyway the transmission is now doing the same thing according to the shop that I took it back to. My first thoughts are if all valves and solenoids were replaced during the first rebuild what could possibly be causing the internal pressure problem? The shop that has the truck said they really are not sure what is causing it. My question is have any of you Tundra owners had this issue with your Tundra? Love the truck but this issue is troubling to say the least. Thanks
  2. Aug 31, 2017 at 3:13 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Did the local rebuild shop warranty the rebuild? If so, I would take it back to them and tell them to call you when they have it fixed.
  3. Aug 31, 2017 at 3:32 PM
    kadashe
    2008 Tundra
    LOL!! yes it has a year warranty on rebuild and that is pretty much what I told them this morning when I took the truck back to them! I was just trying to understand why it can be building excessive pressure if all the valves and solenoids were replaced at the rebuild and I really hate to think like that. This shop has been in business for a lot of years and has a good reputation. That is why I took the Tundra there in the first place
    757TUNDRA likes this.
  4. Aug 31, 2017 at 3:34 PM
    757TUNDRA
    Illinois
    Sounds good. Sorry I can't help. Hope everything works out. There's nothing more aggravating than a problem popping back up after you paid big bucks to have it fixed.
  5. Aug 31, 2017 at 3:38 PM
    kadashe
    2008 Tundra
    Thanks--yes it is frustrating for sure. Love my Tundra--just can not imagine mine is the only one on the road having this issue but I have found no mention of this issue anywhere on the internet. Thanks
  6. Sep 2, 2017 at 1:14 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
  7. Sep 2, 2017 at 1:55 PM
    kadashe
    2008 Tundra
    Thanks--certainly hope the shop has checked these but it will be brought to their attention!
