Transmission problem, 01 tundra 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by Chief 01, Aug 6, 2019.
  1. Aug 6, 2019 at 10:18 AM
    Chief 01
    Chief 01 [OP] New Member
    PA
    2020Tundra Pro Army green
    Being told that possible overdrive bearing, was coming home from vacation, traveling approximately 65, pushed O/D button to slow down slightly, and lost all the gears, does this sound right, never heard of the o/d bearing. No trouble at all before this. (Correct name is o/d planatary gear)
    Partycleman likes this.
  2. Aug 11, 2019 at 7:07 PM
    ldvknight
    ldvknight New Member
    Not sure about the problem, but if it comes down to repairing/replacing the transmission, I would recommend getting a used 2003-2004 tranny from a yard for about $300 and swapping them out. I had a constant check engine code related to my tranny and this fixed it and gave me a better, smoother, stronger, transmission.
    Filthyphil likes this.
  3. Aug 11, 2019 at 7:51 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Mine went out at 54,000 miles in 2002.I bought my 2000 tundra TRD access cab new in April 2000.I noticed after a YEAR OR SO that it would shift hard from 1st to 2nd gear.Took it back to dealership and it wouldn't do anything ! After a couple months it did it again going to work. Sped up getting on the interstate and when it went into overdrive it popped and started grinding and no power to the wheels. Dealership came to interstate and picked it up and said the plantary gear came apart and junked the trans.They replaced it with a new trans and has ran great ever since! I now have 381,000 miles on the truck with no trans problems.I would replace the transmission with a low mileage used one.IMO.
  4. Aug 11, 2019 at 8:36 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Find a used one for sure from a 03-04 and have less than $1,000 into a better unit then what your truck came with.
    revtune and koditten like this.
  5. Aug 11, 2019 at 9:14 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Not familiar the 2002 4X4 Tundra power train controlling computers. Is it necessary to reprogram the ECU, TCU or PCM (if the later two exist) to successfully swap a 2002 4X4 trans to a 03/04 4X4 trans? Does the 03/04 trans have the same bell housing bolt on pattern to 4.7 motor, and no need to reprogram the computer?
    If this is a bolt on no reprogramming trans swap with overdrive still functioning, I'm headed to the junk yard and have it locally rebuilt for less than a remanufactured trans cost from out of state. Lot of bad reports on those reman places. I'll have the later year rebuild laying around to replace the original when it gives from towing appx 5000 lbs several or more times a month. About 114,000 miles, with unburned red fluid, on it now. However long that takes to quit. Thanks guys.
  6. Aug 12, 2019 at 6:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Interesting. You're the first person I've actually seen post about the infamous "planetary gear" issue. Apparently it was a known issue for the 2002's. I'm glad Toyota took care of it for you as they should have.
    @Professional Hand Model here is a point of reference for our 02's.
  7. Aug 12, 2019 at 6:56 AM
    Filthyphil
    Phil
    As far as I know its the same unit as our early models just with upgraded internals, don't believe anything needs to be re-flashed should just be a drop and swap.
    02goes[QUOTED] likes this.
  8. Aug 12, 2019 at 1:28 PM
    Chief 01
    PA
    If it's a definite drop and swap ( from 01 to the upgraded 03 or 04), then it's a no brainer, if I received the news that it needs a remand.
  9. Oct 20, 2019 at 10:18 PM
    Partycleman
    Partycleman New Member
    2002 4.7 access cab
    Hi, I’m having a very similar problem as chief 01 Except I didn’t use the button to shift out of overdrive.
    on the coldest day since I’ve owned the truck ,I noticed the shift lever was difficult to move but once in position th truck drove normally,I went 20 miles to town and made a couple stops,still the shifter lever was hard to move,
    Doing highway speed on the way home I heard a clunk
    And lost power to wheels
    Now now the transmission won’t engage in any gear
    But makes a little grinding noise sometimes even in Park or neutral.
    The park position will engage and hold the truck,and the neutral position is free,
    But the other positionsa are free also
    Is there anything else this could be,stuck shift solenoid or valve.. or even something electrical?
    I’m not too excited about the idea of replacing the tranny
  10. Jan 10, 2021 at 1:22 PM
    Dana
    Dana New Member
    2002 regular cab
    I just acquired a 2002 Tundra that is doing the same as Partycleman. Would like to know what he found out what was wrong with his. I looks like maybe I should be looking for a 03-04 transmission
