Transmission or driveshaft noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by 18tundrasport, Feb 20, 2018.
  1. Feb 20, 2018 at 6:33 PM
    18tundrasport
    18tundrasport [OP] New Member
    PA
    2018 tundra dc sport 4x4 super white
    Lund step bars, afe filter, Trd flow accelerator
    I've noticed when I'm off the gas and go back on it seems the truck makes a clunk noise or something like that. Anytime I'm coasting then accelerate it makes that sound. Any ideas or concerns?
  2. Feb 21, 2018 at 3:54 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Yours being a new truck shouldn't have any slack (and related noises) in the drivetrain. Mine doesn't do that. I'll take it to the dealer if I were you.
    TheBeast likes this.
  3. Feb 21, 2018 at 10:47 AM
    slip sinker
    slip sinker New Member
    2018 Silver DC 4WD
    My '18 does the same thing.
    Rider0120 likes this.
  4. Feb 21, 2018 at 3:23 PM
    18tundrasport
    PA
    Interesting
  5. Feb 21, 2018 at 3:25 PM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    Mine doesn’t. Take it in and let us know what you find.
  6. Feb 21, 2018 at 3:27 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    My 17 doesn’t.
  7. Feb 21, 2018 at 4:07 PM
    Can you post a video to Youtube and post it here so we can hear what you’re talking about?
    TTund16 likes this.
  8. Feb 22, 2018 at 1:54 AM
    TTund16
    TTund16 New Member
    if your car was much older i would say maybe torque converter unlocking!?
    posting a video/audio clip is a good idea!
  9. Jun 29, 2018 at 5:21 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    Any resolution to this one? My 2015 does this.
  10. Jul 1, 2018 at 4:02 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    Mine does that Sporadically and I’m trying to figure out whether it’s in a specific gear or situation. But I have noticed that on mine as well coasting either on a flat Road it will clunk but not consistently
  11. Jul 1, 2018 at 10:50 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    My does this. I don’t hear a clunk more of a slight jerk or bump feeling from behind. It’s hard to explain.
  12. Jul 2, 2018 at 11:33 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    I seem to remember seeing a TSB regarding something like this? I can't seem to find it now though.
  13. Aug 21, 2019 at 6:53 PM
    Dyang
    Dyang New Member
    D
    07 Grey Tundra 4x4 V8 5.7L
    Did you figured it out?
    Mine was doing the same thing, took it to my mechanic and he thought it was the driveline joint, and had it replaced.
    But it still making the same clunking sound and I didn’t get charged for it due to the sound is still there. But now after almost a year of driving it like that seems to get worse now. Every time i slightly let go of my gas pedal it makes that knocking clunky sound and sounds like its either 1. My pinion and ring loose or 2. My tcase.
    2yrs ago before I purchased it i test drove it and had no issue except it was not going into 4H or 4L so the car dealer had to send it to shop to fix the actuator and or might of have replaced another used tcase with working 4H and 4L.
    Long story short, months later down the road I started to hear that clunking and its louder and worser now. Couldn’t get a video because i have no gopro camera to do the job.
    Reason why I haven’t taken it in to dealer was because most ppl here had similar issues and their dealer couldn’t find out what was the issue. So I didn’t want to waste my time till i’ve done my research and find and end to it.
    Please lmk if yours got fixed.
  14. Aug 21, 2019 at 7:25 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    My 2018 does this sporadically as did my previous 2018.
  15. Aug 21, 2019 at 8:41 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I had a 2010 4Runner that did this, based on the description. It was very sporadic, and somewhat rare. I just attributed it to the characteristics of the truck. I haven't noticed it in my 2018 Tundra.
  16. Aug 21, 2019 at 9:15 PM
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Mine has been doing this as well. Specially when I stop then go again sounds like it’s the drive shaft or the rear diff. Has been happening for a few years now
  17. Aug 23, 2019 at 5:37 PM
    Dyang
    Dyang New Member
    D
    Yeah i think it’s the t-case on mine.. its clunking badly at slow speed and yes sounded like its the rear diff or bad tcase to driveline.
  18. Sep 23, 2019 at 10:04 AM
    Trikerider
    2015 Limited CM
    I had the truck at the dealer for a transmission fluid change and brought up this clunk and was able to replicate the clunk while shifting from reverse to drive when the vehicle was checked in, obviously not moving, foot on the brake. You can feel the drivetrain slack get taken up and then get clunk, typically only on reverse to drive. They told me I had a caliper hanging up and that was the noise I was hearing. Very disappointed with the service department, not the first time I've been lied to by them. Of course when I was leaving I wasn't able to replicate it but was soon as I got to work. If I end up with the timing chain noise I had last winter it will be back over there again for the timing chain and then this clunk again.
  19. Oct 11, 2019 at 8:35 AM
    JRTundra
    JRTundra New Member
    Jeff
    Indiana
    2014 SR5 Crewmax 4x4
    So if it wasn't the caliper hanging up, any idea what was really causing it? I have the same sound going on in my '14. Clunks when shifting back and forth from reverse to drive but also while I'm moving. Supposed to have it looked at Monday morning.
  20. Oct 11, 2019 at 11:41 AM
    Trikerider
    2015 Limited CM
    I haven't had a chance yet but was going to have wife replicate the clunk while I tried to check out underneath to see if anything seams like the culprit. Don't know if I trust the wife enough to try this though. I'm thinking it might be something in the pinion on the rear diff. I know when I grease the rear driveshaft there always seamed to be a lot of slack or play in the rear diff. I should try a different dealer.
    JRTundra likes this.
  21. Oct 15, 2019 at 3:53 PM
    dasunsrule32
    dasunsrule32 New Member
    Arizona
    2019 Tundra SR5 Silver Double Cab
    Tonneau Cover OEM Headlight LED Lights Morimoto LED Fog Lights Sports Antenna Running boards LED Turn Signals 18" Vision Manx 2 wheels
    I have a clunk noise on my 19, but it only does it one time and only after going from Park to drive. When I press the gas, it will clunk. Again, it only does it once.
  22. Nov 25, 2020 at 6:51 AM
    Judahtzu
    Judahtzu New Member
    my platinum ‘10 is doing the same thing. Has been increasing in frequency over the last year, especially in tow haul or for a day or two after being in tow haul. We are going to replace all driveline joints and see if that fixes it. I laugh that nobody can really isolate the sound!
  23. Nov 25, 2020 at 8:13 AM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    My 15 had the clunk issues, my dealer said it was the tail shaft needed greasing. They took drive shaft off greased the Tail shaft and went away, for a while now it’s back and just happens to have the extended warranty ran out of mileage this week. So now I’m not sure what to do.
  24. Nov 25, 2020 at 8:40 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Are you guys sure its not just the backlash in the rear ? Feels just like a driveline u-joint with slop, can sometimes be loudish, depends what you call loud.
    My 2019 had a lot of it, after installing the new gears and carrier I can't feel it at all.
  25. Jan 12, 2021 at 11:04 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I know this is an older thread but I think my new 21 has this. From a stop sign on flat ground when I accelerate it almost feels like the gas in the tank shifts back and sloshes with a low sound, could be described as a bump feeling. Does this or the picture of the TSB below sound familiar to anyone?
  26. Jan 13, 2021 at 4:07 AM
    ljburns
    ljburns New Member
    I had this issue. I greased the drive shaft and that fixed the problem. I don't think they were doing it when I took it in for regular oil changes.
    Fiesta346 and Bammer like this.
  27. Jan 13, 2021 at 5:36 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    WOW, dealer not doing what they are supposed to.....:facepalm:
    I'm sliding under my truck tonight and see the condition of my driveshaft..
  28. Jan 13, 2021 at 5:54 AM
    ljburns
    ljburns New Member
    I questioned the service department about it. They assured me the techs are doing it as part of the scheduled service. I had to pump a lot of grease in there. I imagine it was pretty dry. Haven't had any issues since. Make sure to clean up any residual grease from the fittings. It will fling everywhere, even the exhaust. I "cleaned" it up. Thought it was good enough until I started driving down the road and smelled the grease I left behind burning on the exhaust. No fire or even smoke, just that wonderful smell.
    Bammer[QUOTED] likes this.
  29. Jan 13, 2021 at 6:15 AM
    Bammer
    Monroe, CT
    What year is your truck, not sure there is a fitting on my 19?
  30. Jan 13, 2021 at 6:15 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    My truck is 2 weeks old, it shouldnt be the driveshaft lubrication unless they dont normally grease it???? No way it could have dried out already, even in Ca.
