Transmission Oil Cooler Sweat
Discussion in 'General Tundra Discussion' started by AstroDude, May 25, 2023.
  1. May 25, 2023 at 9:29 PM
    AstroDude
    AstroDude [OP] New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    So my 4.6L didn't come with a towing package and therefore didn't come with an oil cooler. Because I offroad and camp a ton, I needed one to due the transmission getting hot.
    So I installed an aftermarket transmission oil cooler for a dually.
    I've noticed that there some sweat or oil on the cooler itself but no where else. I've tightened those clamps down. Any further, I might collapse the inlet.
    Is this normal? I'm going to take it by a mechanic for them to check the oil level but I 100% am not f***in with it.
  2. May 26, 2023 at 10:23 AM
    AstroDude
    Eddie
  3. May 26, 2023 at 11:11 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Definitely looks like it is leaking but not at the clamp. Are you sure the first row weld is intact?
  4. May 26, 2023 at 2:06 PM
    AstroDude
    Eddie
    I'll double check later on to make sure. I'll give you an update
  5. May 26, 2023 at 6:52 PM
    AstroDude
    Eddie
    The metal on metal wore down the oil coolers metal on top and its slowly leaking. I ordered a new one and I'll use some rubber as a bushing on the reinstall.
    Mike59 likes this.
