Transmission not shifting
Discussion in '2nd Gen Tundras (2007-2013)' started by BillyT327, Jul 1, 2024.
  1. Jul 1, 2024 at 11:42 AM
    BillyT327
    BillyT327 [OP] New Member
    2010 Toyota Tundra 2wh
    Shifting problem started day after I used manual shifting when descending mountain. Engine revs up when giving it the gas as if transmission is slipping. I can shift up usuing manual transmission to all 6 gears but even using manual the transmission seems to slip when accelerating. The day before no problems
  2. Jul 1, 2024 at 1:21 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Easy step first. Check level and add fluid. Most issues arise from that. If you get codes then address them accordingly. Fluid change also works, get a graduated pan and see how much you drain and add fresh fluid. If it's never been done, then 1-2000 mile intervals
    BillyT327[OP] likes this.
  3. Jul 1, 2024 at 4:34 PM
    BillyT327
    Thanks for your feedback
