Transmission maybe loosen / slipping?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Sharla001, Aug 22, 2024.
  1. Aug 22, 2024 at 7:25 PM
    Sharla001
    Sharla001 [OP] New Member
    Tony
    2014 Thunder
    None
    I have noticed that when truck is in D the light will flicker and then it feels like it might be loosen / slipping. I was told to maybe have the transmission flushed.
    Any suggestions? Thank you
  2. Aug 22, 2024 at 7:57 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Any T-related problems I'd start w/a 'drain and fill' only (not a full flush), and make sure you're properly checking fluid levels, etc. when you're done. Don't assume it was at proper levels before you started and only put back in what you take out...
