Transmission kicking into 2nd gear
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Sep 2, 2020.
  1. Sep 2, 2020 at 5:20 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Hi all, having an issue which is pretty scary. Driving home the other and out of nowhere I felt a kick going from 1st to 2nd gear. Next day it was fine and shifted smoothly for about 5 mins then started kicking into 2nd again. Next day shifted smoothly on and off and now kicking into 2nd everytime. I tried starting in 2nd gear and it shift smoothly for a while then started kicking going from 2nd to 3rd BUT only when I start in 2nd gear. Once the first kick is over, no matter if I start in 1st or 2nd the trany shifts smoothly the rest of the way.
    Anyone have experience with this or know what it might be? Took it to a trany shop and dude said it might be a spring on valve but just got a call saying he can't figure out what is wrong since all the springs are in working order and that I need a valve body. Quick search online, $1,000 price tag.
    Ouch
  2. Sep 2, 2020 at 5:35 PM
    Professional Hand Model
    Hand Protectors
    DaWhiteTundra likes this.
  3. Sep 2, 2020 at 5:39 PM
    Voss
    Valod
    2003 AC TRD 4x4
  4. Sep 2, 2020 at 5:50 PM
    Hand Protectors
  5. Sep 2, 2020 at 6:07 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Will do
  6. Sep 2, 2020 at 6:08 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I'm going to call them tomorrow. Showed valve springs but Trany guy says valve springs are good.
  7. Sep 3, 2020 at 11:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    How's your fluid look? Is it low/burnt?
  8. Sep 3, 2020 at 12:46 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Clean as can be. See through pink.
    I called Sonnax this morning. They said it could be the solenoids which I had read can go bad on our trucks but Trany guy says the computer wasn't showing a faulty solenoid and that it would show up if one had gone bad.
  9. Sep 4, 2020 at 1:06 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Turns out used transmissions for our trucks are pretty cheap. Toyo Dealership wanted $1,342 for a new valve body, cheapest I found online for true Toyo part was $932. Called a few junk yards in my area and found a 119k mileage trany for $700. Trany guy says he'll replace for $650. This route gets me a much lower mileage trany for about the same as a new valve body would cost from the dealership. Think this is the right way to go about this.
  10. Sep 4, 2020 at 2:38 PM
    Hand Protectors
    Its in your tranny mans hands right now. We have to trust him.
    Voss[OP] likes this.
  11. Sep 4, 2020 at 2:47 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Maybe it’s not a man at all........
  12. Sep 4, 2020 at 2:50 PM
    Hand Protectors
    Excellent point.
  13. Sep 11, 2020 at 12:10 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Trany dude came through... New-er trany in and shifting smoother than ever.
  14. Sep 14, 2020 at 11:13 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did they tell you what went bad exactly?
  15. Sep 14, 2020 at 1:31 PM
    Voss
    Valod
    2003 AC TRD 4x4
    The Valve Body
  16. Sep 14, 2020 at 1:57 PM
    Hand Protectors
    IIRC a new Sonnax Valve Body cost about $400.
  17. Sep 14, 2020 at 3:36 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So was it just easier to replace the whole thing vs pull the valve body and just replace that? I'm completley lost when it comes to the inner workings of automatic transmissions.
    FrenchToasty and Darkness like this.
  18. Sep 14, 2020 at 6:16 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I’ve had bad luck with aftermarket parts in the past. When it comes to mechanical, I stick with genuine Toyota parts.
  19. Sep 14, 2020 at 6:20 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Valve body would’ve been easier but dealership wanted $1,400 for a new valve body. Cheapest true Toyota part I found online was $1,000. Mechanic wanted $400 to replace valve body. Found a lower mileage transmission for $700 and mechanic said he’d swap it out for $650 so I just chose the lower mileage trany over replacing the valve body.
    artsr2002 and bmf4069[QUOTED] like this.
  20. Sep 15, 2020 at 5:45 AM
    Hand Protectors
    Yeah. You did good. The cost was a little more for the newer tranny. I put up the Sonnax Kit recco for DIY purposes. It doesn’t look difficult to install. Hardest part is getting the trans pan bolts off, then its a Plug and Play unit Swap.
    Voss[QUOTED][OP] likes this.
  21. Sep 15, 2020 at 5:50 AM
    Hand Protectors
