Transmission issue
Discussion in '2nd Gen Tundras (2007-2013)' started by swamper, Feb 19, 2022.
  1. Feb 19, 2022 at 9:50 AM
    swamper
    swamper [OP] New Member
    Joe
    Southern nj
    2011 sr5 trd
    2011 4wd tundra,purchased used everything seems good but noticed when cold here in winter shifting manually or just in drive I don’t get a shift or rpm change to 6th gear 6 at transmission . Seems ok when warmed up.
  2. Feb 19, 2022 at 10:06 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    If everything else is working properly, this may not be an actual problem. The truck may be prioritizing warming up over keeping the engine RPMs low.
  3. Feb 19, 2022 at 11:57 AM
    swamper
    Joe
    Southern nj
    2011 sr5 trd
    What I was thinking,,thanks
  4. Feb 19, 2022 at 1:29 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Could be low fluid.
    It's more noticeable in cold weather.
  5. Feb 19, 2022 at 3:09 PM
    timmy2112
    timmy2112 New Member
    2013 CM
    My 13 does the same thing, when transmission temp rises, it shifts ok
    rebmo likes this.
  6. Feb 19, 2022 at 3:28 PM
    13BrownTundra
    13BrownTundra New Member
    2021 SR Double Cab
    My 13 4.6 does the same thing, according to my mechanic it’s normal and they lockout of 6th until warm to prevent damage.
    rebmo likes this.
