transmission flush vs transmission service?
Discussion in 'New Member Introductions' started by travotundi, May 21, 2025 at 9:24 AM.
  1. May 21, 2025 at 9:24 AM
    travotundi
    travotundi [OP] New Member
    Yesterday
    Was wondering on a 2011 5.7 is it safer to flush transmission oil at high mileage than replacing the transmission filter? I heard that once the filter is replaced it could cause problems down the road.
  2. May 21, 2025 at 9:48 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    2010 4.6, I had mine flushed at around 100k factory fluid. Don't remember exact, cashier put down incorrect miles on the invoice. Reason I got her done was washboard feeling around 35-40mph and at the moment of downshifting.
    No problems afterwards. Been about 60k miles already since flush. Time for another one?
  3. May 21, 2025 at 12:19 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. May 21, 2025 at 2:08 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    Replacing the filter doesn't cause problems at all. It's just usually not necessary. Power flushing at a dealer or service center is usually not a good idea and can cause issues afterwards. Especially on a high mileage transmission. Manual flush or drain and fill is your best friend. Plenty of threads for both methods on here. Should be able to find with search. I prefer a manual flush for when I first change the fluid on a new to me vehicle. That way I can get most of it out and I know exactly what I have. Then drain and fills regularly after that.
