Transmission flush and fill ?
Discussion in 'Performance and Tuning' started by Dabutcher, Oct 3, 2017.
  1. Oct 3, 2017 at 11:54 AM
    Dabutcher
    Dabutcher [OP] New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    called Lexus by me to get service quote. $279.00. Call Toyota by me for a service quote. They said it never needs any service unless you are having trouble? Says it has some fancy named full synthetic fluid. I am coming up on a 100k and am just trying to treat my truck with love and compassion with proper maintenance. Thanks. D
  2. Oct 3, 2017 at 1:11 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If I were you I’d def get her flushed and filled just for peace of mind. 100k is a lot of miles for not changing fluids in anything, synthetic or not.
    kenomouth64 likes this.
  3. Oct 3, 2017 at 3:51 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I just had mine done along with both diffs. Total cost OTD was right at $400. Its hard to imagine any lubricating fluid retaining its protective properties in excess of 100k miles. 'unless you are having troubles' is a key phrase here. Our goal is to prevent those troubles to begin with. Or put another way, I think your dealer is FOS.
    Amasailor30 and tomsinamerica like this.
  4. Oct 3, 2017 at 5:37 PM
    Dabutcher
    D
    Twin Cities
    First dealer was Maplewood Toyota and then I call Inver Grove Heights Toyota for a quote for flush and fill. They also said it does not need any service unless there are problems. Maybe I will play a little game and keep calling Toyota service depts til I get a different answer. Peace. D
  5. Oct 3, 2017 at 6:47 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Several local dealers in OK gave the same line of shit, when I wanted to get mine flushed. I finally found one that performed the service for $239.99. I watched them perform the service (I was at 130k miles) and let me tell you that fluid was straight black, no red. They were trying to tell me it never needed to be done...
    Amasailor30 likes this.
  6. Oct 3, 2017 at 6:51 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Yeah they must be getting that line from Toyota. I suppose it might have made sense back when the average life expectancy of an engine was 100k. Nowadays, that's just getting broken in, and the transmissions have to keep up.
    kenomouth64[QUOTED] likes this.
