Transmission fluid
Discussion in '1st Gen Tundras (2000-2006)' started by shoe07, Feb 1, 2021.
  1. Feb 1, 2021 at 8:38 AM
    shoe07
    shoe07 [OP] New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I’m planning on doing two drain in fills of the transmission. I read Toyota’s owners manual and found they want type T-IV.
    I know idemitsu is a supplier of oil for Honda (unsure who Toyota’s is) and make quite good products. Their TLS is the Toyota equivalent type T-IV. This price appears decent for 5 qts.
    I was going to check in with the local Toyota dealer on their price for the oil.
    Do we have a consensus on oils for the transmission? My searching netted tons of gen 2 and gen3 stuff. Didn’t find much on gen 1
    I also plan on doing a coolant change. I read it takes 11+ qts. So I expect I’ll need 3 gallons? Was going to get the Toyota super long life.
    ick23 likes this.
  2. Feb 1, 2021 at 8:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I use Valvoline Maxlife. Best price is at Wal-Mart. When you do a drain+fill you'll get out 4-5 quarts.
    We have other members that like the non-synthetic version https://www.walmart.com/ip/Valvoline-DEX-MERC-ATF-Automatic-Transmission-Fluid-1-QT/15125788
    I'm sure you can't go wrong with either one. I'm not familiar with the one you linked but it seems expensive.
    A good alternative to Toyota coolant is Zerex Asian blend. It apparently check all the boxes needed for our trucks. FYI, there are two 10mm drain plugs on the bottom of the engine block used to drain all the coolant.
    https://www.walmart.com/ip/Valvolin...-006-1775e83003a03b&athancid=null&athena=true
    Darkness and SouthPaw like this.
  3. Feb 1, 2021 at 9:04 AM
    shoe07
    Ohio
    Thanks for the info, are these drain bolts obvious? Could someone refer their location out of the fsm?
  4. Feb 1, 2021 at 9:16 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    As soon as you crawl under there you will see the pan for the transmission. Your 04 should be the same as mine. The drain bolt will be obvious. You will refill through the dipstick.
    Darkness likes this.
  5. Feb 1, 2021 at 9:27 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    GreenMachineDream and Darkness like this.
  6. Feb 1, 2021 at 9:35 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I used Mobil 3309 in mine the last time since I was able to buy a case for $60. Next time I plan to use Valvoline Maxlife ATF since it now lists Toyota Type IV as a supported type.
    Bonus as it's only $18 for a gallon.
    ick23 likes this.
  7. Feb 1, 2021 at 5:58 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Another Valvoline max life vote here. It’s cheap, synthetic and available at any Wally World/parts store. Not sure how old/good my trans fluid was when I bought the truck but after the first drain and fill, it was immediately shifting smoother. It’s part of my oil change routine now.
  8. Feb 2, 2021 at 5:38 AM
    shoe07
    Ohio
    Thanks everyone for your feedback
  9. Feb 2, 2021 at 4:50 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    In my neck of the woods, the Toyota dealer is hands-down favorite on price...competitive with Stuff Mart and certified approved for your truck.
  10. Feb 2, 2021 at 5:15 PM
    SouthWestGA
    SouthWestGA New Member
    Another MaxLife user here for over 100k miles and no issues. Drain and Fill. Then Repeat as needed.
  11. Feb 2, 2021 at 5:26 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    the Toyota stuff is just as approved as the DeX 3 valvoline atf I use. On my atf plug on my 01 tundra it says DeX 3 right on it, for parts I'm all about Toyota only, including oil filters and such. But fluids, eh
  12. Feb 2, 2021 at 5:41 PM
    shoe07
    Ohio
    Checked with my dealer and they charge 8.25 a qt. No thank you.
    going to grab a couple gallons of the max life.
    Pucks18 likes this.
  13. Feb 2, 2021 at 5:55 PM
    Pucks18
    Exactly, and with less expensive fluid you are more prone to change the fluid out more often, imo
  14. Feb 4, 2021 at 5:56 PM
    tmac58star
    Unless you spend it on tasty, frosty beverages...in which case you might buy the wrong fluid.
    Pucks18 likes this.
  15. Jul 22, 2023 at 12:45 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Is there supposed to be a gasket on the bolt plug for the ATF pan? I’m doing a drain refill on my 2000 Tundra and there was no gasket on the bolt….
  16. Jul 22, 2023 at 2:06 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 AC has a thin fiber washer on the ATF drainplug
  17. Jul 22, 2023 at 2:14 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The original was fiber type washer (non-crushable). Subsequent replacements were a metal crush gasket.
    I’ve had my truck since new so I know.
  18. Jul 22, 2023 at 2:16 PM
    Jack McCarthy
    Bill
    North of Boston
    Goto the dealer and pick up a $2-$3 crush gasket. They all have them in stock.
    FrenchToasty likes this.
  19. Jul 22, 2023 at 2:25 PM
    2TunGet1
    Weird, mine didn’t have that. First time I’ve ever changed the ATF oil and I’ve owned the entire 23 years.
    I already screwed it back in with no washer and there are no leaks so far. :fingerscrossed:
  20. Jul 22, 2023 at 2:32 PM
    2TunGet1
    I also just unscrewed the ATF plug on my 2001 Sequoia and no washer/gasket either :monocle:
  21. Jul 22, 2023 at 2:48 PM
    Jack McCarthy
    Bill
    North of Boston
    Maybe they didn’t have them originally then later decided to have one in the middle of the production year?
  22. Jul 22, 2023 at 4:22 PM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    For what my two cents is worth I'd recommend always going with OEM fluid straight from the dealership. For the extra $3 a quart I get peace of mind dealing with a critical unit. However, I'm a big fan of either Aisin or even the stuff from WallyWorld. Cheers!
