Transmission fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by JCTX, Dec 2, 2020.
  1. Dec 2, 2020 at 9:57 PM
    JCTX
    JCTX [OP] New Member
    Jacob
    2014 Tundra 5.7l v8
    Good evening all,
    I have a used 2014 Tundra with 107k miles. I’ve never changed the transmission fluid and not sure if it was changed before I bought it. I wanted to ask if a drain or flush is recommended? Is it even a good idea to do now or just fill? Should I also consider changing the transmission filter?
    Thanks in advance,
    Jacob
    YardBird likes this.
  2. Dec 3, 2020 at 2:33 AM
    SShooterZ
    SShooterZ New Member
    Drain and refill would be my recommendation. Flushing, especially with those miles, could be a little risky IMO.
    2mchfun, equin, timdske and 1 other person like this.
  3. Dec 3, 2020 at 3:25 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Agree. A flush would only be asking for trouble IMHO.
    2mchfun and JCTX[OP] like this.
  4. Dec 3, 2020 at 4:36 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Like was said above, drain and refill
  5. Dec 3, 2020 at 4:51 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    No to changing the transmission filter.
    First, it's usually described as a strainer, not a filter. That means this "filter" does not remove 20 micron size particles, only big chunks.
    Second, attempts to remove the transmission pan bolts will usually result in you breaking several off in the holes. It will be a genuine pain to drill out the pieces and helicoil the holes, even with professional level skills.
  6. Dec 3, 2020 at 4:59 AM
    JCTX
    Jacob
    2014 Tundra 5.7l v8
    Thanks everyone! I appreciate the suggestions/guidance. I’ve been reading a ton of contradictory info online and this just helps with my decision.
    2mchfun likes this.
  7. Dec 3, 2020 at 5:00 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    Drain and fill only. Most shops I've worked at require the customer to sign a release form for a trans flush when they have high mileage vehicles.
    2mchfun, Saltyhero13 and JCTX[OP] like this.
  8. Dec 3, 2020 at 1:34 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    It's a filter, not a strainer, I tore mine open when I changed it and posted pics. Its a type of media fabric, not a metal strainer. Best way to describe the function of this particular filter is like a sock, so if you took a sock and stuck a water hose in the end, thats how this filter works. I guess that's the best way I can describe it haha. I have pictures of it in my transmission thread but don't have the pictures on my phone anymore.
  9. Dec 3, 2020 at 2:42 PM
    JohnLakeman
    Maybe by your definition it's a filter.
    In Toyota's world it's called a strainer. I'm just using Toyota's name for it. But, you can name it anything you want. In any event, Toyota says it's "maintenance-free".
  10. Dec 3, 2020 at 4:43 PM
    Sumo91
    TN
    Ahhh i see, I thought you were meaning a metal screen strainer. And yes I would say its lifetime. Mine had very very minimal material in it at all at 176k miles when I changed it
    Saltyhero13 likes this.
  11. Dec 3, 2020 at 5:10 PM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    Just did my first d&f at 38k miles on my '18.
    My technique was to drive up to the door of my local dealer, get out, and check in with the nice lady. She took my truck and I went and drank coffee while looking at gun magazines. About 45 mins later, she gave me my truck back and I gave her $90.
    Easy peasy!
    831mic, Johnsonman, tttrdpro and 6 others like this.
  12. Dec 3, 2020 at 5:11 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    And by my definition a colander is a spaghetti filter.
    Also, delightful rigatonis.
  13. Dec 3, 2020 at 5:25 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  14. Dec 21, 2020 at 8:26 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Have we ever received any concrete info as to the drain intervals? I'm at 50k and local dealership keeps brushing me off the idea.
  15. Dec 24, 2020 at 5:00 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    read the maintenance guide included with your owners manuals. It shows 60k for any severe use like towing etc..
    2mchfun and Wallygator like this.
  16. Jan 24, 2021 at 9:47 AM
    KillaahCam
    KillaahCam New Member
    Cameron
    North East Texas
    2014 MGM 1794 Crewmax 4x4
  17. Jan 24, 2021 at 10:09 AM
    JohnLakeman
    For AB60F transmission (5.7L 4WD), reference volumes for filling pan, valve body, and torque converter are 2.2, 5.0, and 6.4 quarts respectively. Add another 1 quart for the transmission fluid cooling circuit, plus another quart for safety: 15-16 quarts. You may find you use less because of duplication in the reference volumes, so make sure you can return unused, unopened containers.
    2mchfun likes this.
  18. Jan 24, 2021 at 10:32 AM
    KillaahCam
    Cameron
    North East Texas
    Thank you.
    JohnLakeman likes this.
  19. Jan 24, 2021 at 10:51 AM
    Vizsla
    Vizsla pretend2send
    12 qts is just enough, so 13 qts to be safe.
    FrenchToasty likes this.
  20. Jan 25, 2021 at 4:59 PM
    737fixer
    737fixer New Member
    Please understand EXACTLY what this process entails. While I 100% agree with the "Drain & Fill" process telling someone to order 12 qts or 13 to be safe I feel were giving this person the belief that since his transmission holds slightly more then 12qts when you buy 12qts you changing everything. The "Drain & Fill" process does NOT come close to changing all your transmission fluid. When you drain the transmission your actually removing less then 4qts. Then you fill it up and drive around. You have successfully accomplished the "Drain & Fill" procedure. But understand you have only changed about 30% of your total fluid. If you do it again you will remove 30% of the bad fluid but also 30% of the good/new fluid you just changed. So two complete "Drain & Fill" procedures get about half of your bad fluid changed. The advantage of the dealer transmission flush is your changing about 95+% of the bad fluid. Great right. No No No. The machine is extremely rough on the system and disturbs a lot of old sediment and this can get into places you don't want. Plus the old school adage of some old fluid is actually good in the system but you can look that up elsewhere. If you want to buy 12qts at once that would be great in that three separate "Drain & Fills" would be awesome but again your still leaving about a third of old fluid behind.
    Henry1jg and Saltyhero13 like this.
  21. Jan 25, 2021 at 6:20 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    My dealer wanted to keep the truck over night so they could get it to the proper temp. I said the heck with that and just did it myself.
  22. Jan 25, 2021 at 6:41 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    So my truck is a 2017 with 40k on the clock. Is a dealer service still dangerous at this mileage? Should I get it changed? The manual seems to say it doesn’t need it yet. The engine oil has been changed every 5k. I’m tempted to get the diff and transaxle changed too, but again, the manual doesn’t say to do it.
  23. Jan 25, 2021 at 7:00 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I think manual says 30k on axles. I don't change transfer case after changing on Tacoma at 50k and it looked like it came out of the bottle. Drain and fill on transmission at 60k.
    AZBoatHauler likes this.
  24. Jan 31, 2021 at 10:43 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I called my dealer and they said they use a system that flushes all fluid out in a slow even way and it is not a flush. Were they just BS'ing me? Plus, what is all this getting the transmission to temperature stuff? Is that just if you remove all fluid and put in new? If you only drain and fill you don't worry about temperature, right?
  25. Jan 31, 2021 at 11:42 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Provided that the tranny was properly filled before you drain it you can measure what you remove and replace with same. I have done this on 2 Tacomas and Tundra with no problems. I tried on the Tacoma to get it in the temp check mode but never could get it to work.
    Ronin73[QUOTED] likes this.
  26. Jan 31, 2021 at 2:50 PM
    737fixer
    737fixer New Member
    I can't say what type of machine your dealer will use to flush your transmission. Can't say that some new type of machine is much less aggressive with is flush procedure. After this much time and problems with the old method I wouldn't be surprised that a better unit exists but I have not heard of it. Not sure I willing to take the word of the guy who's job relies on selling me maintenance but again I can't say he's lying. Concerning the drain and fill temperature question you absolutely still have to use it to properly get the exact amount of fluid in your pan. I agree that you can just replace the same amount you removed but then you are assuming that the level was correct beforehand. I use the OBD Fusion App so I can literally have my phone in front of my face when its time to pull the plug but when I first did it I tried all three methods and found they were all within couple of degrees of each other. Use the gear shifter method, the laser temp gun method, or any OBD App since they are all getting the information from the same sensors that the gear shifter method is receiving. Understand that the fluid expands as the temperature rises but lets be realistic about that expansion. If your garage is 30 degrees in upstate Maine or me in 110 degrees Phoenix or when the temp is maxed a 230 degrees then Toyota writes a manual for their own protection cause then the difference means something. Missing the exact temperature by a few degrees is not a worry and that person should probably worry more about having the truck level when he started the job. Everyone who has leveled their truck 2+ inches in the front but then panics over missing the drain temp but 5 degrees is already.............should probably end it there.
    mqqn and Sumo91 like this.
  27. Jan 31, 2021 at 5:33 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
  28. Jan 31, 2021 at 8:14 PM
    737fixer
    737fixer New Member
    This system is or WAS outstanding. Too bad Toyota thought removing the transmission cooler yet still charge for it was a great idea as for some of 2018, 2019 and newer this video is not effective.
  29. Jan 31, 2021 at 9:16 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I changed my tranny fluid around 125k the first time. I change it every 40k now. I beat the living piss out of my truck towing, plus over sized tires don't help. I had some funny Shifting at 198k changed fluid back to normal. I'm currently at 278k I changed the fluid a week or two ago. I have the stealership do it. I haven't had any issues with them changing it they get it done within a day, the truck runs fine. The tranny blows up at this point I'll get it rebuilt.
    I believe the temp thing they're talking about has to do with it being a sealed tranny.
  30. Jan 31, 2021 at 9:31 PM
    Sumo91
    TN
    Well stated. The only thing I have to disagree on, is that the trd pros are leveled from the factory and require the same procedure to check the level of the fluid.
