Transmission fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oregon 1 Toyo, Mar 23, 2019.
  1. Mar 23, 2019 at 1:05 PM
    Oregon 1 Toyo
    Oregon 1 Toyo [OP] New Member
    2014 Tundra sr5 double cab 4x4
    whats the average quarts that are drained from a tundra transmission pan when doing a drain and fill?
  2. Mar 23, 2019 at 1:09 PM
    I've seen mentioned here around a gallon to 5 qts.
  3. Mar 23, 2019 at 3:04 PM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    I drained my 08 expecting about 3.8 qts. Big surprise. The gallon jug filled to the neck and it was still coming. Put 4 qts back in and took it to the shop for fluid level adjustment. They said it was " a little overfilled". Fine a container that can hold 6 qts.
    bc
  4. Mar 23, 2019 at 4:35 PM
    Oregon 1 Toyo
    Thanks for the info!
