Transmission fluid
Discussion in '2nd Gen Tundras (2007-2013)' started by Apollothetundra, Nov 24, 2018.
  1. Nov 24, 2018 at 3:20 PM
    Apollothetundra
    Apollothetundra [OP] New Member
    Trevor
    07 Super White 5.7l V8 295,000
    3 quarts for the transmission that doesn't seem like much. Who else has changed their' s? 154310152916373828392.jpg
  2. Nov 24, 2018 at 3:59 PM
    Professional Hand Model
    Hand Protectors
    Its the perfect amount unless you are refurbing the entire transmission. A trick to flushing your transmission of all the old is to do two consecutive back to back changes a few days apart.
    jeremyd and Apollothetundra[OP] like this.
  3. Nov 25, 2018 at 6:01 PM
    chiefbeerdrinker
    chiefbeerdrinker Need I say more?
    Hollister ca
    White truck goes fast
    None
    Can this be done at home on a 2nd gen?
  4. Nov 25, 2018 at 6:28 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Yes, just exchange all of the fluid while you are at it. It will not hurt anything. I've done it on three different Toyota's without any negative consequences. Google Tundra transmission flush for instructions
  5. Nov 25, 2018 at 6:33 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    https://www.youtube.com/watch?v=fLVZSoKbyZ0
    Goes pretty much like this for a 2nd gen. Probably similar for a 3rd gen as well. I used OEM Toyota Fluid. It really isn't that bad to do this.
  6. Nov 25, 2018 at 6:34 PM
    Atomic City Tundra
    Devin
    New Mexico
    3 quarts is only if you do a drain and refill on the pan. If you do a full fluid change, you will use quite a bit more. I think I used around 12 quarts to get everything looking clean.
    teedubbya likes this.
  7. Nov 29, 2018 at 12:41 AM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Will be doing things soon. 112,5k miles on what I can only assume is the original fluid.
  8. Nov 30, 2018 at 1:13 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    At 42K I did not think I needed to change the filter but I dropped the pan to clean the magnets. Ended up putting about 5.5 quarts back in. Take notice of how much comes out and use that as a reference to start with.
