Transmission Fluid
Discussion in '1st Gen Tundras (2000-2006)' started by CombatPOG, Sep 29, 2018.
  1. Sep 29, 2018 at 7:12 AM
    CombatPOG
    CombatPOG [OP] New Member
    Dustin
    2001 Toyota Sequoia Limited 4wd
    Ok guys, I have 1gen Sequoia 4wd and been needing to change the transmission fluid and filter. I have about 233k on the dash. Just seeing what some of y'all recommend or use. I do a lot of driving and spend a few times a week driving trails. Thanks
  2. Sep 29, 2018 at 7:26 AM
    Professional Hand Model
    Hand Protectors
    Check your manual. It should be DEXRON II or III (same product). Sold at auto stores. My 02’ Tundra automatic takes 2.1 qts.
    Let us know how it goes!
    CombatPOG[QUOTED][OP] likes this.
  3. Sep 29, 2018 at 7:27 AM
    Hand Protectors
    DEXRON II OR III is the same fluid for your power steering. You can turkey baste suck and fill a couple cycles to refresh that reservoir with your extra .9 qts.
    CombatPOG[OP] likes this.
  4. Sep 29, 2018 at 7:28 AM
    CombatPOG
    Dustin
    I was doing some research and saw that. Going to need to get this done before our trip to Neb.
  5. Sep 29, 2018 at 8:15 AM
    CombatPOG
    Dustin
    Was reading up on the filter, so I guess it will be a drain and fill... I'll do it a couple of times to try to get mostly everything out of the Torque Converter.
  6. Sep 29, 2018 at 8:25 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah, I don't bother dropping the pan to get at the filter. I just drain and refill roughly every 40k. If you haven't done it in a while I would do it and plan another soon to dilute the old fluid. I buy Toyota fluid for mine but many use other brands.
    The flush methods are a bit risky and have some horror stories, dump and refill is pretty safe.
    Jerry311SD and CombatPOG[OP] like this.
  7. Sep 29, 2018 at 8:30 AM
    CombatPOG
    Dustin
    I'll just drain and re-fill, Thanks for the heads up.
