Transmission Fluid
Discussion in '1st Gen Tundras (2000-2006)' started by maseb42, May 6, 2024.
  1. May 6, 2024 at 5:47 PM
    maseb42
    maseb42 [OP] New Member
    2006 4.7 Tundra RWD DC
    Recently changed all three U-Joints and my carrier bearing, but lost some transmission fluid when I pulled the driveshaft from the transmission. however I can’t seem to find a good video for an 06 DC for checking transmission fluid levels or doing a transmission fluid drain and refill.
  2. May 6, 2024 at 7:00 PM
    shifty` In South Dakota Trouble ain't hard to find
    WAtundra4x4 likes this.
  3. May 6, 2024 at 7:04 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I definitely lost fluid when doing my radiator change and then a little more when I removed the radiator to do my timing belt/water pump.
    haven't added any. Haven't had any issues. I should probably get on that; but you know.....Toyota made it more difficult than it had to be....
  4. May 6, 2024 at 7:09 PM
    maseb42
    Thanks, Shifty!
    shifty` likes this.
