Transmission fluid - what to use and how often?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 45er, Jul 12, 2025 at 7:22 PM.
  1. Jul 12, 2025 at 7:22 PM
    45er
    45er [OP] New Member
    Rob
    2021 SR5 Crew Cab 4x4
    Tonneau Cover
    I just changed the oil on my 2021 4WD Tundra. 59,000 miles. I'm thinking about changing transmission fluid in the next few months but was wondering how often does it really need changing? Most of my miles are in a rural area and I very rarely tow a trailer.
    Also, is Toyota transmission fluid absolutely necessary or are there others out there that perform just as well?
  2. Jul 12, 2025 at 7:30 PM
    Dgravee
    Dgravee New Member
    2010 tundra sr5 crewmax
    I’m no pro - literally just did my first one 10 minutes ago. I believe Toyota recommends 60k for a drain and fill.
    As for the fluid, from the sounds of it the overwhelming majority of people say put Toyota WS fluid back in. I tend to agree just on the basis that when you drain and fill you’re only getting a few quarts out and who knows how different brands play together when they are mixed. Hope this helps
    Tripleconpanna, Tundra2n3 and chugs like this.
  3. Jul 12, 2025 at 10:54 PM
    blenton
    blenton New Member
    WS ATF, drain and fill every 30k miles.
    mverkaik, TXBrit, Mdl and 1 other person like this.
  4. Jul 13, 2025 at 12:00 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Toyota WS, Idemitsu TLS LV and AISIN work well. I'd opt for 30k fluid changes. If you have a cooler which would be advisable you can almost do a complete fluid change instead of a few quarts here and there.
    Some have good luck with the global fluids which are based on dex 6.
    blenton likes this.
  5. Jul 13, 2025 at 12:00 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x3
    WS ATF and D & F every 30k
    blenton likes this.
  6. Jul 13, 2025 at 2:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I do my own D&F every 30k-ish miles.
    I installed the cooler early on.
    I have used Valvoline Maxlife ATF from the get-go.
    WS=WS
    I'm at 125k miles.
  7. Jul 13, 2025 at 5:18 AM
    45er
    Rob
    Tonneau Cover
    Good advice here. Thanks to all. When you say "drain and fill", are you just talking about draining the fluid from the drain plug at the pan? Not removing pan, cleaning the magnet and filter and replacing pan with new gasket? My dealership wants $350 to "drain and fill" but they suck the oil out and drain it. Seems like a lot for not taking the pan off.
  8. Jul 13, 2025 at 5:31 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive done it 4 times now at 135k. Maxlife for all changes
  9. Jul 13, 2025 at 5:40 AM
    45er
    Rob
    Tonneau Cover
    Do you just drain what you can from the plug in the pan and replace that volume?
  10. Jul 13, 2025 at 5:44 AM
    No. After draining, you refill with slightly more than what came out. There is a procedure that involves getting the fluid up to temp and opening the check plug and letting the extra come out until it’s just a dribble. Then it’s full. If it’s low, and you didn’t know it and just put the same amount that came out back in, it would be low after your D&F.
    nobodyintexas likes this.
  11. Jul 13, 2025 at 5:48 AM
    Octane957
    Octane957 New Member
    I'm at 74K and to my knowledge mine has never been changed. I am the second owner. I am wanting to do it but nervous. I am not nervous about doing the work. I have just always heard if you change it after a certain amount of mileage, I may be doing more harm than good. I am open to opinions on that.
  12. Jul 13, 2025 at 5:52 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Drain and fill is “safe”
    trans flush is not “safe”
    if you can change oil. You can d&f a Toyota trans. It’s easier.
    blenton and Tunrod like this.
  13. Jul 13, 2025 at 5:53 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    this needs to be repeated in every d&f thread
    it sounds complicated
    it’s not
    I can do it
    blenton likes this.
  14. Jul 13, 2025 at 5:54 AM
    Octane957
    Thank you! I have never been a fan of a trans flush no matter how many miles. The fluid still looks good, But I would like to start changing regularly regardless. Thank you for the info!
  15. Jul 13, 2025 at 5:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    And don’t clutch your pearls over the correct “temp”. When you check it
    EVERY time I’ve done mine it took 5 minutes to get to that temp
    I don’t even bother with the temperature thing
    warm a few minutes . Check valve thing
    wait for trickle
    close it
    ftr. 3.8 qts drain out in 10minutes
    I add a gallon of maxlife.
    I get rid of the excess during the check valve process
    KNABORES likes this.
  16. Jul 13, 2025 at 6:04 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Sorry for my ignorance, but I have no idea about this. Is there a post that explains a bit more or can you elaborate?
  17. Jul 13, 2025 at 6:12 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  18. Jul 13, 2025 at 6:17 AM
    It’s even listed as a “temperature range” in the procedure description. When warm, the fluid expands some and flows easier. Those two things make it give you the proper level when coupling the check plug. Doesn’t have to be exactly 115° F. Has to be in a range around 99°-111° or so IIRC.
    How about a video
    https://youtu.be/NUAuGmDGntY?si=4c5hCPIS0caOkv8G
    FrenchToasty and Tunrod like this.
  19. Jul 13, 2025 at 10:52 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Basically. Get a pile of the crush washers from the dealer, same size for drain and check plug. 24mm socket opens up the fill plug, no gasket on that one.
    I wouldnt stress too much on the fluid level, get close and you’re likely good. I have a trans temp on the scan guage so it makes the checking procedure a ton easier
