Transmission fluid type
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Apr 29, 2020.
  1. Apr 29, 2020 at 12:37 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I do not have an owners manual for my 2001 tundra 4x4 and i need to do a tranny drain and refill. I need to know what the fluid specs are, if no one knows for sure that is okay then, i will just go buy fluid from the dealer despite knowing im going to get charged up my butt for it. Also about how many quarts does a drain and refill take? Any tips for me? Ive never done transmission service ever and I'm an inexperienced 20 year old. Thanks
  2. Apr 29, 2020 at 12:41 PM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    The one & only.. for pan it’s 4.5 to 5 quarts, but for entire flush I believe it’s 12-14? Someone step in
    773_eddie likes this.
  3. Apr 29, 2020 at 2:25 PM
    Pucks18
    @MrAristo ok. Thanks, thats what i like to see
    MrAristo likes this.
  4. Apr 29, 2020 at 2:59 PM
    Pucks18
    Where do you buy the fluid at? I cant find the fluid anywhere other than ebay and Amazon, and im too worried about it being fake.
  5. Apr 29, 2020 at 3:10 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Jorg4709, MrAristo and FrenchToasty like this.
  6. Apr 29, 2020 at 3:24 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I use Valvoline Max Life ATF. It’s cheap and available at your local Wally World.
    DaWhiteTundra, Richid and YardBird like this.
  7. Apr 29, 2020 at 3:37 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Your 2001 calls for Dexron III. Type T-IV is backwardly compatible and is fine, but kind of expensive. Any Dex-III will work for the transmission and the power steering system.
    Don't overthink this -- any fluid that meets Dex-III spec will be fine. I used Valvoline Dex/Merc from Advance Auto.
  8. Apr 29, 2020 at 4:19 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    3rd for Valvoline, shifts great and no issues
  9. Apr 29, 2020 at 5:31 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Valvoline Max Life here.
  10. Apr 29, 2020 at 6:01 PM
    SouthWestGA
    SouthWestGA New Member
    another max life synthetic vote from me
  11. May 2, 2020 at 4:45 AM
    Professional Hand Model
    Hand Protectors
    OP has a 2001 which has the A340 Transmission. The spec is DEXIII. Marbles bought the last pure DEXIII formula in the world.
    Here is what I’ve been using. Its cheap at Wallywurrlld at around $14 a gallon. You’ll need 2 gallons. Use the extra on your Power Steering fluid change. Same fluid goes there.
    The service fluid change is easier than a oil change. Usually takes about 4-4.5 quarts. Measure your stick with engine warm and on level ground. I try to get my fluid reading on the high end of the stick.
    Richid, ToyotaJim, revtune and 3 others like this.
  12. May 2, 2020 at 4:53 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Any local Toyota dealers nearby? Best bet. I know local shops/garages also sometimes will have bulk orders of stuff like this they get for themselves, might be willing to sell to customers also.
  13. May 3, 2020 at 6:13 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Check the Parts Dept. at your nearby Toyota dealer...or order it online. Just do it man.
  14. May 4, 2020 at 8:16 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I go through so much of this I should own stock in the company.
  15. May 4, 2020 at 10:13 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You and PHM both. I think he's on the board of directors. :D
  16. May 4, 2020 at 10:22 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    He changes it "just cause". I add it cause my truck HATES ATF. Everytime I put it in he spits it back out! Trans, PS, doesn't matter.
  17. May 4, 2020 at 10:23 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  18. May 5, 2020 at 4:10 AM
    JLag01AC
    JLag01AC New Member
    2001 Access Cab
    Valvoline Maxlife for me. Did a pan drop filter and gasket change with a little over 4 qts changed out in my 2001 AC. Plan to drain and fill a couple more times this year to get more refreshed. Shifts great. Incidentally did this to our 2009 tranny growling RAV4 earlier this year and now it shifts great. My son also uses it in his 2005 vibe/matrix without incident. So far so good using Maxlife
  19. May 5, 2020 at 11:41 AM
    Pucks18
    @bmf4069 wait so should i use dex/merc or max life? Max life is the red bottle, and your using the blue bottle
  20. May 5, 2020 at 11:44 AM
    Pucks18
  21. May 5, 2020 at 11:54 AM
    Hand Protectors
    Use the pic that @bmf4069 put up. You want DEX/Merc.
    Reason I do not use Maxlife is it has other non necessary additives (for our A340 trans) to satisfy a larger range of other vehicle transmissions.
    DEX/Merc is more specifically tailored to our transmission and costs less.
    bmf4069 likes this.
  22. May 8, 2020 at 10:38 AM
    Pucks18
    Headed to wallyworld after work today to pickup dex/merc, thanks for the info on why its more sensible to use dex/merc instead of maxlife hand model.
    bmf4069 likes this.
  23. May 8, 2020 at 10:51 AM
    Hand Protectors
    Anything I can do for wurrld peas. Grab a funnel (to pour the Dex into the trans tube) with a stiff straight tube versus that Mickey Mouse type with the flexible accordion tube. The skinny funnel should slip right into the truck trans filler tube neck.
  24. May 8, 2020 at 11:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, blue. I use it for my PS juice too.
  25. May 8, 2020 at 11:16 AM
    Pucks18
    @Professional Hand Model i can totally see the funnel being tilted too far toward the front of the truck with the way our tranny sticks are and spilling a shit ton. Might buy 3 gallons! Hahaha
    bmf4069 likes this.
  26. May 8, 2020 at 11:17 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If you need, theres a single 10mm bolt holding the tube on. Its tucked up under the head in a pita spot.
    Pucks18[QUOTED][OP] likes this.
  27. May 11, 2020 at 9:30 AM
    Pucks18
    For anyone visiting this thread for similar info, i did a drain and fill and put exactly 4 quarts in and my tranny level is perfect. By far easiest thing you can do on your truck. Will do another one in the next 200 miles or so.
    bmf4069 likes this.
  28. May 11, 2020 at 10:33 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You can hold off till your next oil change, unless you absolutely want to.
  29. May 11, 2020 at 11:00 AM
    JLag01AC
    JLag01AC New Member
    2001 Access Cab
    I agree it’s easier than an oil change - unless your dropping the pan and changing out the filter and gasket which is fairly easy as well. And probably the safest way to replenish tranny fluid.
  30. May 11, 2020 at 2:23 PM
    Hand Protectors
    Most everyone I’ve asked here on this forum that has done a pan drop reports that their filter and pan magnets were pretty clean. If I ever had to do an entire fluid content change, I’d just do thru the in and out hoses at the radiator. The pan drop seems like lots of work not to mention those pan bolts liking to snap.
    bmf4069 likes this.
